UPDATED: SMath Studio 0.98.5905 (02 March 2016)
UPDATED: SMath Studio 0.98.5905 (02 March 2016) - 消息
#21 已发布: 2016/3/2 12:12:26
1,443个赞,共2,936个帖子。
new beta release 0.98.5905 available, should fix problems even for those who didn't update plug-ins
All links are already updated (see #1)
(on behalf of Andrey)
2位用户喜欢此帖子
NDTM Amarasekera 2016/3/2 14:50:00, Andrey Ivashov 2016/3/2 14:10:00
#22 已发布: 2016/3/2 13:38:20
1,558个赞,共1,868个帖子。
Maple Wrapper plugin can help with some symbolic problems.
2位用户喜欢此帖子
Andrey Ivashov 2016/3/2 14:10:00, NDTM Amarasekera 2016/3/2 14:51:00
#23 已发布: 2016/3/2 14:57:39
983个赞,共6,866个帖子。
Hello Uni,
Which one is right, which is wrong ?
Personally: I would scrap Smath from subscripted variable.
#24 已发布: 2016/3/2 15:08:07
1,558个赞,共1,868个帖子。
All answers are correct. I just have invisible braces. If you click on the expression, then they appear. I don't know why it happened.
#25 已发布: 2016/3/2 22:43:40
983个赞,共6,866个帖子。
I trust you Uni, because I know you tell the truth.
But an an algebraic result to be copied as such, wrong.
Maple does not like subsrcipt. That by clicking it shows
the brackets, to me it is a bug that it does not
output the right result.
I accept the subscript as a local tutorial demo.
For real work and particularly for publishing: NO subscript.
Cheers, Jean
#26 已发布: 2016/3/2 23:16:00
983个赞,共6,866个帖子。
I have a 30 page SMath file that does not run on 0.98; The error points down to the summation function
I the worst instance, I noticed Sum limited to N = 11
My Ksmoothlet takes over 100. I didn't pursue
the hypergeometric as it turned red at very low N.
Too low N for that is useless as it flies in the blue.
In the fft/icfft [about two months ago], the length of
accepted N is not constant. Puzzling, live with it.
Attach the part of the work sheet that points the Sum error.
#27 已发布: 2016/3/3 01:22:33
1,558个赞,共1,868个帖子。
Don't worry about subscripts. For the variables subscripts supported as was described here.
If Maple Wrapper meet a variable with the dot (comma) in its name this name will wrapped with the symbol `. You can see this in log file (\mvr5\mvr5.txt).
The log for int(x.1,x.1):
03.03.2016 9:20:29 [->] smath_int(`x.1`,`x.1`)
03.03.2016 9:20:29 [->] C:\Temp\tmpAC26.tmp:
interface(quiet=true);
with(linalg):with(inttrans):with(plots):
writeto("C:\\Temp\\tmpAC27.tmp":
smath_line := proc() local i: for i from 1 to nargs - 2 do args[i]; od: end:
smath_sum := proc() if nargs = 1 then sum( args[1] ); elif nargs = 2 then sum( args[1], args[2] ); elif nargs = 4 then sum( args[1], args[2] = args[3] .. args[4] ); fi: end:
smath_product:= proc() if nargs = 1 then product( args[1] ); elif nargs = 2 then product( args[1], args[2] ); elif nargs = 4 then product( args[1], args[2] = args[3] .. args[4] ); fi: end:
smath_int := proc() if nargs = 2 then int( args[1], args[2] ); elif nargs = 4 then int( args[1], args[2] = args[3] .. args[4] ); fi: end:
smath_diff := proc() if nargs = 2 then diff( args[1], args[2] ); elif nargs = 3 then diff( args[1], args[2] $ args[3] ); fi: end:
smath_sys := proc() { args[i] $ i = 1 .. nargs - 2 }; end:
smath_el := proc() args[1][ args[2] ]; end:
smath_mat := proc()
local i, j, out:
out := [ args[j] $ j = 1 .. args[ nargs ] ]:
for i from 2 to args[ nargs - 1 ] do
out := out, [ args[j] $ j = ( i - 1 ) * args[ nargs ] + 1 .. ( i - 1 ) * args[ nargs ] + args[ nargs ] ]:
od:
 convert( [ out ], array );
end:
smath_submatrix := proc() submatrix( args[1], args[2] .. args[3], args[4] .. args[5] ); end:
ans := \
smath_int(`x.1`,`x.1`):
if ( whattype( ans ) = `exprseq` ) then
    convert( convert( cat( `mat(`, substring( convert( [ans], string ), 2..-2 ), `,`, nops( [ans] ), `,1)` ), string ), symbol );
elif ( whattype( ans ) = `set` ) then
    convert( convert( cat(`mat(`,substring(convert(map2(op,2,[ans[i]$i=1..nops(ans)]),string),2..-2),`,`,nops(ans),`,1)`), string ), symbol );
elif ( whattype( ans ) = `symbol` ) then
    convert( convert( eval( ans ), string ), symbol );
elif ( whattype( ans ) = `series` ) then
    convert( convert( ans, polynom) , symbol );
elif ( whattype( ans ) = `string` ) then
    convert( ans, symbol );
else
    convert( convert( ans, string ), symbol ); fi;
quit:
03.03.2016 9:20:29 [<-] C:\Temp\tmpAC27.tmp:
1/2*`x.1`^2
03.03.2016 9:20:29 [<-] 1/2*x.1^2
Davide Carpi 2016/3/3 13:33:00
#28 已发布: 2016/3/3 01:48:09
983个赞,共6,866个帖子。
Uni,
I most appreciate you know Maple and prove/demonstrate
it takes subscript. Why the 1rst display was wrong ?
Not disaster as we have to copy/paste result, doing
like you mentionned earlier click to see the bracket.
Can you make the attached "Fourier Quantum" work ?
Fourier Quantum.sm (25.51 KiB)已下载 1599 次。
#29 已发布: 2016/3/3 05:49:33
1,558个赞,共1,868个帖子。
Why the 1rst display was wrong?
I don't know. May be Andrey will see this and make some comments.
#30 已发布: 2016/3/11 20:32:51
2,344个赞,共4,057个帖子。
组: Super Administrator
Hello.
Thank you for figuring it out!
Issue was in Math Region. It is fixed now. Fix will be available in new SMath Studio build.
2位用户喜欢此帖子
Davide Carpi 2016/3/11 22:09:00, frapuano 2016/3/12 03:25:00
