1页(3条)
Paste Problem in Ubuntu - 消息
Dear Developers
In Ubuntu 8.04 and 9.04 "paste" cannot be used, just doesn't work.
I tried all possible ways to paste an equation after "cut" or "copy" but all did not show any result.
I tried, Ctrl-V, press the paste button, also from the menu Edit > Paste.
Is it a bug or is there any way to copy an equation and paste somewhere to modify?
Regards, waluyo
Regards, waluyo
I know about this bug (someone already mentioned about it). As I understand it is happens on some OS' under Mono. I've tried to fix this but had no success. Will try again soon. Thanks for the report!
For the time being in Ubuntu, copying a formula and paste it to different place is possible, by selecting "inside" the formula region and paste (or Ctrl-V) it somewhere. Of course I can copy maximum 1 region only. But at least this trick helps me, I do not need to retype again similar equation within SMath,
Regards, Waluyo
Regards, Waluyo
1页(3条)
