1页(14条)
Offset surface creation - 消息
An initial surface is given, given by the "createmesh" function, which forms a
network with nodes.
Dyou want to create an offset surface, offset by an amount h from the initial.
The direction of displacement surface epends on the sign of h.
Sequence of calculation:
1.Restoring the normal from the nodal points of the initial surface and we get
the nodal points of the displaced surface.
2.We connect the resulting node points
The image is built on three-dimensional graphics and can be rotated with the mouse
network with nodes.
4位用户喜欢此帖子
Andrey Ivashov 2021/10/19 13:48:00, Oscar Campo 2021/10/20 18:42:00, Davide Carpi 2021/10/20 08:27:00, Alvaro 2021/10/10 20:58:00
Hi,Rezorex.I put the icon with the link using the "hyperlink" insert.
Here is a link to an article from Mapleprimes
https://www.mapleprimes.com/posts/211000-Preparing-A-Parametrized-Surface-For
Hi. Thanis Ber. A slightly different version, using only parametric functions.
Offset surface creation.sm (73.49 KiB)已下载 1557 次。
Offset surface creation.pdf (917.17 KiB)已下载 1050 次。
2位用户喜欢此帖子
Thanks Alvaro, I continue to learn from you.
Fridel.
Fridel.
Converting Surfaces to Solids
The solid is formed from the initial surface, the offset surface, and the
lateral surface that connects them. The lateral surface is formed by normals
reconstructed from the boundary nodal points of the initial surface.
Solid.sm (36.96 KiB)已下载 1557 次。
Solid.pdf (309.58 KiB)已下载 927 次。
.png)
.png)
Alvaro 2021/10/20 23:56:00
Thanks ► Fridel, Alvaro
I don't have the courage to convert SS 6179 ... OK.
Keep up ... Jean.
Rotate 3D TREASURY_2 Parametric Explorer.sm (33.72 KiB)已下载 1534 次。
Keep up ... Jean.
WroteConverting Surfaces to Solids
Hi Fridel. Thanks, great job. In the attached an alternate mesh. Its advantage is that it consists of a single coordinate matrix, so it can be manipulated more easily, with translations, rotations and deformations. As disadvantages, it does not look so good and there may sometimes be a wrong line, but I guess only one.
pSolid_alternate_mesh.sm (51.99 KiB)已下载 1484 次。
pSolid_alternate_mesh.pdf (391.97 KiB)已下载 864 次。
Fridel Selitsky 2021/10/21 05:07:00
Normal to the surface on Rezonar's triangular mesh
NorSurAlvaro.sm (49.33 KiB)已下载 1591 次。
NorSurAlvaro.pdf (623.77 KiB)已下载 926 次。
.png)
.png)
Alvaro 2021/10/24 23:40:00
By same token, did you manage constructing Delaunay ?
We had no chance in Mathcad. Cheers ... Jean.
Hi. The same but with a different version for the triangular mesh.
NorSurAlvaro v2.sm (77 KiB)已下载 1494 次。
2位用户喜欢此帖子
2位用户喜欢此帖子
2位用户喜欢此帖子
Creating surface thickness with triangular meshes
thickness.sm (56.02 KiB)已下载 1596 次。
thickness.pdf (732.98 KiB)已下载 964 次。
.png)
.png)
1页(14条)
.png)
