Fit Data Primer
Fit Data Primer - Fit Data Primer - 消息
#1 已发布: 2019/2/25 22:02:56
983个赞,共6,866个帖子。
This document, freshly brewed, is a recast of the Genfit Procedure.
Now the fitted coefficients result from β:=Minimize(init,iter)
1. compose the model
2. assign the vector gradient
3. β:=Minimize(init,iter) ... done
The 3 examples are 1/1 MCD 11 except that "iter" is not automated.
By setting "iter" high enough that will worth automated.
The setup is identical to MCD where Minerr is applied to SSE from
the solve block Given/Minerr [CG, QN, LM options]
Genfit algo [init, iter] UFO Copy.sm (106.06 KiB)已下载 1132 次。
#2 已发布: 2019/2/26 16:35:46
983个赞,共6,866个帖子。
... refreshed for better publishing:
all respective modules collapsed in utilities.
This is a new example.
Genfit [HV_WEZ].sm (45.64 KiB)已下载 1020 次。
#3 已发布: 2019/3/4 19:36:58
983个赞,共6,866个帖子。
... Frame work guide line, minimalist tool box.
Genfit Pharmacokinetics al_nleqsolve.sm (28.51 KiB)已下载 1267 次。
Genfit [Algo Minimize(Cholesky)].sm (14.31 KiB)已下载 1122 次。
GenfitMatrix Copy Master ToolBox.sm (59.97 KiB)已下载 1212 次。
Genfit Pharmacokinetics L-M {ShortVersion] Copy.sm (101.33 KiB)已下载 1334 次。
#4 已发布: 2019/3/4 23:24:06
983个赞,共6,866个帖子。
... original L-M c/w solution Table
Genfit Pharmacokinetics L-M Copy.sm (114.42 KiB)已下载 1239 次。
