The procedure for constructing a circle by three points in 3D
The procedure for constructing a circle by three points in 3D - 消息
#1 已发布: 2016/12/31 04:11:54
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Idea of ​​the algorithm taken from the publication of Alexey Ivanov
http://www.mapleprimes.com/posts/207697-Circle-In-3d-
The calculation algorithm
1. The three points are vertices of the triangle. Write three linear equations:
two equations of planes passing through the midpoints of the two sides of the triangle
perpendicular to these sides: f1 = 0, f3 = 0
and the equation of the plane which contains the triangle: f2 = 0.
2. Solve the system of equations and find the center of a circle with coordinates Cen xCen, ... zCen.
3. Find the circle radius R of the equation of a sphere with radius R and center at Cen
4. Construct a circle as the line of intersection of the sphere with the plane of the triangle (Draghilev method)
Okruzhnost'3.sm (55.35 KiB)已下载 1392 次。
2位用户喜欢此帖子
Davide Carpi 2017/1/2 12:40:00, Oscar Campo 2017/11/25 00:44:00
#2 已发布: 2017/1/24 13:22:48
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Modified the program
OkruzhnostMod.pdf (243.54 KiB)已下载 989 次。
OkruzhnostMod.sm (67.93 KiB)已下载 1359 次。
3位用户喜欢此帖子
Davide Carpi 2017/1/25 06:32:00, Oscar Campo 2017/11/25 00:44:00, Arie 2017/1/24 19:58:00
#3 已发布: 2017/11/24 06:43:33
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Changes:
1. Circle is constructed by matrix transformation, and not Draghilev Method
2. The normal to the surface passing through the given points is shown.
OkruzhnostMod3.sm (54.16 KiB)已下载 1332 次。
3位用户喜欢此帖子
Davide Carpi 2017/11/24 14:53:00, Oscar Campo 2017/11/25 00:44:00, frapuano 2017/11/24 08:35:00
#4 已发布: 2017/11/25 10:33:16
983个赞,共6,866个帖子。
Thanks Ber7, saved.
#5 已发布: 2017/11/25 12:21:20
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Hi, Jean, thanks for the support.
