issues using transpose
issues using transpose - 消息
#1 已发布: 2013/3/17 07:46:57
1,443个赞,共2,936个帖子。
Theare are a couple of issues using the transpose function:
1) Using transpose inside sum(1), the selection box loose the bottom piece of the sum symbol; when you select and move to top the primitive, some artifacts appears on the screen.
2) linear indexing of transposed matrices doesn't work (as reported here)
best regards,
w3b5urf3r
