rank
rank - 消息
#1 已发布: 2020/4/19 08:24:42
haweHofmann
haweHofmann
3个赞,共32个帖子。
Hallo zusammen,
DimEigenraum: (n-rank(A-λ*E))=1@#
should be 2
some steps of elementary row additions later
is 2
https://de.smath.com/cloud/sheet/vooDFR4FbP
any idea whats wrong?
#2 已发布: 2020/4/19 10:08:10
1,443个赞,共2,936个帖子。
This link doesn't works, be sure to use the share button link (on the right of the save button), because the address bar link is restricted to the author only.
#3 已发布: 2020/4/19 10:19:42
haweHofmann
haweHofmann
3个赞,共32个帖子。
Upps, sorry
Made a link
https://de.smath.com/cloud/worksheet/3BgYDE7e,
Maxima pure
(%i6) A: matrix([1,1,1,-1,0],[0,1,0,0,1],[0,0,0,1,0],[0,0,-1,2,1],[0,0,0,0,1])$
(%i7) A-1*ident(5)$
(%i5) rank(A-1*ident(5));
(%o5) 3
but
Maxima(rank(A-1*identity(5)))=4
or
#4 已发布: 2020/4/19 13:37:27
1,362个赞,共2,276个帖子。
The referenced sheet seems to use Maxima(). This doesn't work, as third party plug-ins aren't available in the cloud version.
It is better to attach such files here.
#5 已发布: 2020/4/19 13:50:54
983个赞,共6,866个帖子。
rank(M) ... matrix rank is Smath built-in.
Here is a most precious application.
Matrix PseudoInverse.sm (111.21 KiB)已下载 1237 次。
#6 已发布: 2020/4/19 14:09:48
haweHofmann
haweHofmann
3个赞,共32个帖子。
and in how far do your example explain the incorrect calculation
the Maxima part calculate the single eigenvalue which is set manually in cloud version
SMath Studio 0.99.6884 - [JordanMatrix5x5-5fachEW-HV.1.2.Stufe.sm_]_2020-04-19_19-07-08.jpg
JordanMatrix5x5-5fachEW-HV.1.2.Stufe .sm (47.19 KiB)已下载 1197 次。
#7 已发布: 2020/4/19 23:51:44
1,139个赞,共1,805个帖子。
Hi. You're right, it's a bug and there are no way to make this works (numerical nor symbolic):
First column is zero and 3th = - 4th columns, so can't be rank = 4.
#8 已发布: 2020/4/20 11:51:33
983个赞,共6,866个帖子。
Just advanced maths above the classroom.
Your example replies bug from incorrectly threaded input.
As given, your [5*5] matrix has no mathematical meaning.
Page1 rank.sm (11.74 KiB)已下载 1372 次。
sergio 2020/4/20 12:15:00
#9 已发布: 2020/4/20 14:19:49
983个赞,共6,866个帖子。
... clean the bugger
What application do you have for "rank(,) ?
Don't confuse with Rank in Data Analysis.
rref [Row Reduce Echelon Function] is a damned long monkey business.
Has it been done in Smath ... Watson ?
#10 已发布: 2020/4/20 14:51:32
983个赞,共6,866个帖子。
... Rank(V)
Given a set of data values, the rank of each value is the position
at which that value appears in a sorted list of the data.
When values repeat, the rank is an average of the indices where
the value occurs after sorting.
