Text subscript/superscript?
Text subscript/superscript? - 消息
#1 已发布: 2023/5/28 18:58:22
JP
JP
0个赞,共6个帖子。
Can we add a subscript to text in SMAth Studio?
I am not referring to variables. I know I can type '.' and then add any subscript.
#2 已发布: 2023/5/28 20:41:58
983个赞,共6,866个帖子。
You can subtext a text from Writer region.
#3 已发布: 2023/5/30 11:16:25
⚜ Kenny Lemens, P.E. ᵂᴵ
85个赞,共181个帖子。
Greetings,
I found this gem on the internet (https://community.cvent.com/forums/community-home/digestviewer/viewthread?MessageKey=d60af70b-7b4b-4d89-91a2-a2e7edc1eb6a&CommunityKey=693148f0-28e3-495e-a369-16642c2a4f4f&tab=digestviewer); Just copy/paste the subscript of your choice.
//Consolidated for cut-and-pasting purposes, the Unicode standard defines complete sub- and super-scripts for
//numbers and common mathematical symbols ( ⁰ ¹ ² ³ ⁴ ⁵ ⁶ ⁷ ⁸ ⁹ ⁺ ⁻ ⁼ ⁽ ⁾ ₀ ₁ ₂ ₃ ₄ ₅ ₆ ₇ ₈ ₉ ₊ ₋ ₌ ₍ ₎ ),
//a full superscript Latin lowercase alphabet except q ( ᵃ ᵇ ᶜ ᵈ ᵉ ᶠ ᵍ ʰ ⁱ ʲ ᵏ ˡ ᵐ ⁿ ᵒ ᵖ _ ʳ ˢ ᵗ ᵘ ᵛ ʷ ˣ ʸ ᶻ ),
//a limited uppercase Latin alphabet ( ᴬ ᴮ ᒼ ᴰ ᴱ ᴳ ᴴ ᴵ ᴶ ᴷ ᴸ ᴹ ᴺ ᴼ ᴾ ᴿ ᵀ ᵁ ⱽ ᵂ ),
// a few subscripted lowercase letters ( ₐ ₑ ₕ ᵢ ⱼ ₖ ₗ ₘ ₙ ₒ ₚ ᵣ ₛ ₜ ᵤ ᵥ ₓ ),
//and some Greek letters ( ᵅ ᵝ ᵞ ᵟ ᵋ ᶿ ᶥ ᶲ ᵠ ᵡ ᵦ ᵧ ᵨ ᵩ ᵪ ).
You also have the ability to select a different font type/size (e.g., 「Microsoft Uighur」) to produce a subscript effect.
May this be of Good Help;
#4 已发布: 2023/5/30 13:54:26
Oscar Campo
Oscar Campo
135个赞,共309个帖子。
You can insert subscripts and superscripts inside a text region by typing "Alt + =" to insert a math region:
InsertSubscripts&Superscripts.mov (3.87 MiB)已下载 895 次。
Best wishes,
Oscar
#5 已发布: 2023/7/30 22:07:53
soomoon
soomoon
1个赞,共42个帖子。
https://skyground21.blogspot.com/2023/07/insert-subscripts-and-superscripts.html
#6 已发布: 2025/6/25 13:20:43
Spinach
Spinach
0个赞,共3个帖子。
Best wishes,
Oscar
Type '.' and then add any subscript, what should be type to add a superscripts?
Best wishes,
#7 已发布: 2025/6/27 08:50:45
1,362个赞,共2,276个帖子。
Best wishes,
There is no mechanism for text superscripts like the '.' for text subscripts. Thus you have to use special characters as already mentioned here. Of course, if the subscript is to represent a power, then use the power operator '^'. It won't be part of the variable name, however.
已编辑 2025/6/27 08:51:06
