XY Plot -X and Y axis with variables
XY Plot -X and Y axis with variables - Control the plot axis with calculated values - 消息
#1 已发布: 2021/10/25 19:06:06
Lloyd Snell
Lloyd Snell
0个赞,共8个帖子。
This is a continuation of learning to plot in Smath, heck learning Smath.
I have been able to get the XYplots correctly done.
But now I am searching for a solution to define the x- and y-axis min maximum values using calculated values (See the Variables for setting plot axis values ... section).
I am aware formatting X-Y Table, but have not been successful in using it as a place holder for the calculated values, all seems to be static.
Looking forward to your responses.
Lloyd
2D Plot - Axis Control.sm (13.1 KiB)已下载 1254 次。
#2 已发布: 2021/10/25 21:13:15
600个赞,共1,381个帖子。
There is a function to change the XYPlot settings, setprop().
Here is a demonstration for your file.
And below you can find examples for setprop() settings.
2D Plot - Axis Control_r1.sm (14.61 KiB)已下载 1321 次。
XYPlotTools.sm (48.94 KiB)已下载 1337 次。
Oscar Campo 2022/11/4 18:46:00
