Variables evaluation
Variables evaluation - Symbolic to numerical substitution and evaluation - 消息
#1 已发布: 2022/4/12 16:14:10
Mario Acevedo
Mario Acevedo
0个赞,共11个帖子。
Dear all:
I am new to Smath Studio, great software!
Even I am new to its usage, I am trying quite complicated calculations I guess.
I am putting the following lines:
As you can see, I am using Maxima plugin and the Maxima function ev() to substitute values in the symbolic variable. I have some specific questions:
1.) Is there an alternative way to do this kind of calculations without using the Maxima plugin?
2.) v is a system of values, each value is an equality, is there an automatic way to generate a system of values?
Thank to all the people that could help.
#2 已发布: 2022/4/12 17:04:06
1,362个赞,共2,276个帖子。
I can't open your image. From what you describe, you might want to use the substitution function at() from Custom Functions plugin.
at.sm (22.23 KiB)已下载 1300 次。
#3 已发布: 2022/4/12 18:16:56
983个赞,共6,866个帖子。
Attach your Smath document.
#4 已发布: 2022/4/12 18:51:35
983个赞,共6,866个帖子。
#5 已发布: 2022/4/12 19:41:47
Mario Acevedo
Mario Acevedo
0个赞,共11个帖子。
Sorry about the image, now the image is visible.
What I want is to iterate over a set o values to substitute in a variable a store the results in a variable, something like this:
Is there a way to do this substitutions in an iterative way?.
I mean: using a set of programming lines?
In this worksheet I copied and pasted the lines to perform the iterations, but in a general problem solving it is desirable to iterate automatically.
#6 已发布: 2022/4/12 20:20:21
Mario Acevedo
Mario Acevedo
0个赞,共11个帖子。
Here is the Worksheet:
Worksheet1.sm (10.95 KiB)已下载 1261 次。
#7 已发布: 2022/4/12 20:45:20
Mario Acevedo
Mario Acevedo
0个赞,共11个帖子。
Thank you Martin Kraska, at works fine and is what I needed.
It seems that to iterate I have to declare the sys vector by myself, isn't it?
Thanks a lot!
#8 已发布: 2022/4/12 21:29:50
983个赞,共6,866个帖子。
An iterative process is a solving process.
As you say, you just want to plug something from command line.
#9 已发布: 2022/4/12 23:45:16
Mario Acevedo
Mario Acevedo
0个赞,共11个帖子。
wow!, this is what I was looking for!!!, THANK YOU very much Jean Giraud!
#10 已发布: 2022/4/13 07:41:58
127个赞,共342个帖子。
I take inspiration from Jean, but I use the Vectorize function and I forget the size of U
显示剧透
FunzioniVettori.sm (6.37 KiB)已下载 1258 次。
#11 已发布: 2022/4/13 08:21:09
Martin_B
Martin_B
22个赞,共84个帖子。
Pay attention! The definition of M(r) doesn't make much sense.
#12 已发布: 2022/4/13 08:41:51
983个赞,共6,866个帖子。
Superb Sergio ... added in the main document.
#13 已发布: 2022/4/13 09:48:44
600个赞,共1,381个帖子。
An algorithm can also be used.
It may be simpler by this way.
Worksheet1_algorithm.sm (4.69 KiB)已下载 1299 次。
#14 已发布: 2022/4/13 14:10:35
Mario Acevedo
Mario Acevedo
0个赞,共11个帖子。
Nice implementation!!
Just a question, does the S variable had to be declared and dimensioned previous to its use?
I will try the code asap!
Thank you !
#15 已发布: 2022/4/13 14:48:08
Martin_B
Martin_B
22个赞,共84个帖子。
You should always define variables used as arrays in function before assigning elements.
Worksheet1_algorithm.sm (8.04 KiB)已下载 1279 次。
sergio 2022/4/13 16:00:00
#16 已发布: 2022/4/13 16:04:10
983个赞,共6,866个帖子。
Just a question, does the S variable had to be declared and dimensioned previous to its use ?
No, it sets by itself within the for loop.
Wise to clear within the algo ... U:=0
That will avoid interaction with else U above document.
Algo style is an immense companion in Smath.
Personally, I use it as much as possible,
it enables the local command line.
Cheers ... Jean.
Maths algo style MATRIX in_extenso.sm (5.88 KiB)已下载 1305 次。
#17 已发布: 2022/4/13 16:47:50
600个赞,共1,381个帖子。
MarB is dead right.
Array variables should be considered carefully if they will be redefined multiple times.
Or they can be undefined and named uniquely. I tend to name variables in functions this way.
You can find below how I would name your functions variables.
Pretends mess of misusage.
#18 已发布: 2022/4/13 17:55:24
1,443个赞,共2,936个帖子。
It isn't required but it is good practice. If the variable name already exists you might fall in some unexpected cases when the dimensions are different. In addition to the above suggestions, you can use also a Clear(S) as initializer.
