if without else?
if without else? - 消息
#1 已发布: 2010/11/9 14:10:14
Konrad
Konrad
1个赞,共24个帖子。
Hiyah,
How do I do if without else, like this (Mathcad):
And how do I insert images into posts on this forum without using photobucket or the likes?
Konrad
#2 已发布: 2010/11/9 14:41:06
325个赞和1个踩,共2,052个帖子。
Hello Konrad,
Here it is:
The "if" is actually performed as the function with three parameters - if(3). There is no "if" without "else" in SMath. I do not know if Andrey could introduce if(2) - function with two parameters, the "if" without "else". This was mentioned few times by some users.
About inserting pictures in the post, just look at the Notes on Using the Forum please. There you will find the explanation on how to upload the pictures by using SMath Wiki File Management and put their links in the posts of the Forum.
#3 已发布: 2010/11/9 17:01:16
Konrad
Konrad
1个赞,共24个帖子。
Thanks Radovan. That's a pitty, let's hope a two-argument if will come one day :-)
Konrad
#4 已发布: 2013/3/9 07:14:53
fanda
fanda
0个赞,共4个帖子。
yes, that's something, which could make user functions easier to understand and to look better.
+1 on this
Thank you for considering it,
Fanda
#5 已发布: 2013/3/14 08:21:30
dan
dan
0个赞,共4个帖子。
any way i can print a message in a for loop?
i have 3 cases that change 2 variables, but it would be useful to know in which case i'm in
thanks in advance
#6 已发布: 2013/3/14 10:08:17
1,443个赞,共2,936个帖子。
Something like this?
regards,
w3b5urf3r
zoneCases.sm (8.59 KiB)已下载 1548 次。
#7 已发布: 2013/3/18 08:31:18
dan
dan
0个赞,共4个帖子。
yes that did it,
thank you
