bug with function with programming
bug with function with programming - calling function with a for loop loops forever - 消息
#1 已发布: 2019/10/14 22:03:17
jcuadra
jcuadra
0个赞,共12个帖子。
Firstly thank you for such a wonderful free alternative to MathCad 15.
Please see attached .sm file.
The comments describe the bug ...
Thanks in advance
test bug.sm (16.34 KiB)已下载 1532 次。
#2 已发布: 2019/10/15 04:54:29
325个赞和1个踩,共2,052个帖子。
Thanks in advance
Did not reproduce it...
2位用户喜欢此帖子
Arie 2019/10/15 10:16:00, NDTM Amarasekera 2019/10/15 11:01:00
#3 已发布: 2019/10/15 10:16:05
Arie
Arie
94个赞,共285个帖子。
I could not reproduce either..
#4 已发布: 2019/10/15 10:59:18
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Yes, did not reproduce.
#5 已发布: 2019/10/15 13:02:21
jcuadra
jcuadra
0个赞,共12个帖子。
Hmm,
I just re-tested on my home PC, freshly booted, same problem.
appVersion(3) = "0.99.7030" not .7219 <- Could this be the difference?
#6 已发布: 2019/10/15 13:17:34
Arie
Arie
94个赞,共285个帖子。
Hmm,
I can confirm this hangs on 7030. I was running 7219 before and did not have an issue. My guess is this should be fixed in next stable release and already seems to be fixed in Beta releases. The question is whether or not the "fix" is intentional or not.
#7 已发布: 2019/10/15 13:22:49
jcuadra
jcuadra
0个赞,共12个帖子。
OK thanks.
I will install 7219.
Hopefully my Maxima plugin continues to work.
#8 已发布: 2019/10/15 17:43:18
983个赞,共6,866个帖子。
IMHO, not the best option yet.
Who can guess what the angle for loop should be doing ?
There are no maths associated with !
#9 已发布: 2019/10/15 18:05:01
983个赞,共6,866个帖子。
test bug Red.sm (20.37 KiB)已下载 1456 次。
#10 已发布: 2019/10/15 20:26:19
jcuadra
jcuadra
0个赞,共12个帖子。
angle was originally used as such, but I modified it as a troubleshooting step, with no change to the bug's behavior
loss := loss + I2ttot(sin(angle*deg)*Ipk)
#11 已发布: 2019/10/15 20:42:45
jcuadra
jcuadra
0个赞,共12个帖子。
OK thanks.
It works properly on .7219.
But Maxima doesn't work.
#12 已发布: 2019/10/16 14:09:24
Arie
Arie
94个赞,共285个帖子。
What error do you get? Maxima works fine on my end. May need to update the plugin.
#13 已发布: 2019/10/16 16:26:24
jcuadra
jcuadra
0个赞,共12个帖子。
^ Doesn't installing Maxima require running Update16.sm which will then upgrade it to .7030?
EDIT: I was able to get Maxima running with .7219.
#14 已发布: 2019/10/16 18:34:02
983个赞,共6,866个帖子。
No matter SS version, by far not a Mathcad clone.
Show some Mathcad snippets ... would help doctor the patient.
What from Maxima ? Plot, Solve ...
#15 已发布: 2019/10/17 09:30:53
Arie
Arie
94个赞,共285个帖子。
Not sure? Maybe Martin can answer. I already had maxima setup on a previous version. I simply updated to 7219 and Maxima came along for the ride.
#16 已发布: 2019/10/17 10:14:05
jcuadra
jcuadra
0个赞,共12个帖子。
I was able to install Maxima with .7219, thank you.
