1页(4条)
W, VA and VAR units of power - 消息
In AC circuit analysis the VA (Volt Ampere) and VAR (Volt Ampere Reactive) are used.
It will be nice to be added [W=VAR]. All are equivalent to Power in dimensions.
Basile
Can you provide an example that creates problem not having "VAR" if VAR=W.
Basile
Jean,
Currently, I defined the units and use them.
I propose that the VA and VAR become part of the power UNIT.
Basile
Basile
1页(4条)
