Select from file
Select from file - 消息
#1 已发布: 2015/6/25 05:09:58
dansuciu
dansuciu
0个赞,共1个帖子。
Hi there,
I have a large amount of initial data, that can vary depending on many conditions.
Each initial parameter has a set of parameters specific to it. i.e. concrete class C6/7.5 has a different compresive strength than C8/10 and so on
Of course, i want to create my algorithm as parametric as possible.
I was thinking of making some tabular data for them, but not sure if i can make smath read from another file, as to make the final file with results as clean as possible.
Any help or suggestion is appreciated.
Thank you.
#2 已发布: 2015/6/25 12:10:52
Ernesto
Ernesto
13个赞,共74个帖子。
You can try playing around with the ComboBoxList Extension. Attached is an example.
Expand the area to see the data I used.
Double click on the ComboBoxList region to see settings.
Davide Carpi 2015/6/25 15:05:00
