Differentiation operator does not evaluate symbolically
Differentiation operator does not evaluate symbolically - Translate a differential operator from SMath to Maxima - Messages
#1 Posted: 2020/5/30 21:46:04
Alvaro Gavilán
Alvaro Gavilán
26 likes in 68 posts.
Do you know why or what could be the problem for SMath not translating properly a dy/dx. I need to write these operators in Maxima to solve a differential equation...
Thanks in advance,
Differentiation.sm (9.34 KiB) downloaded 877 time(s).
#2 Posted: 2020/5/30 22:23:02
Alvaro Gavilán
Alvaro Gavilán
I have found a workaround, with eval_string() from Maxima.
Differentiation.sm (13.39 KiB) downloaded 867 time(s).
#3 Posted: 2020/5/30 23:55:54
1,106 likes in 1,784 posts.
Hola tocayo. Is this the problem?: always it is diff(y,x)=0, but diff(y(x),x) remains unevaluated and is the correct form to express the derivative of a function.
frapuano 2020/5/31 04:51:00
#4 Posted: 2020/5/31 00:16:30
Alvaro Gavilán
Alvaro Gavilán
Hola tocayo, muchas gracias!
Problem solved:
#5 Posted: 2020/5/31 08:12:03
You are mixing two CAS that will not pass QA [Quality Assurance].
My understanding is that what was usable from Maxima is native in Smath.
Smath native derivative operator works from book library.
sin(x), ln(x), exp(x) ... OK
Gamma(x), erf(x) ... zap. We have them otherwise.
Differentiation.sm (17.82 KiB) downloaded 889 time(s).
#6 Posted: 2020/5/31 10:29:55
Alvaro Gavilán
Alvaro Gavilán
Thank you Jean, I am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
#7 Posted: 2020/5/31 12:42:32
Very few DE have symbolic solutions, unless from Handbooks.
Few of them are available in Smath ... will be back on that.
#8 Posted: 2020/5/31 18:46:56
If Mathcad Prime does not solve those attached ... Oh !
Cheers ... Jean.
ODE Symbolic 4_Flies.sm (130.62 KiB) downloaded 891 time(s).
ODE Symbolic Bernoulli.sm (11.38 KiB) downloaded 923 time(s).
ODE_Laplace 1rst [Type 2].sm (22.68 KiB) downloaded 702 time(s).
ODE Symbolic Verhulst [Logistic].sm (25.55 KiB) downloaded 765 time(s).
ODE Symbolic Lambert.sm (21.81 KiB) downloaded 902 time(s).
ODE_Laplace 1rst [Type 1].sm (24.7 KiB) downloaded 723 time(s).
ODE_Laplace 2nd [Type 3].sm (34.62 KiB) downloaded 776 time(s).
ODE Symbolic Eiffel.sm (21.45 KiB) downloaded 860 time(s).
