Help! Having problems with solve function
Help! Having problems with solve function - 消息
#1 已发布: 2014/11/23 00:49:08
critzker
critzker
0个赞,共1个帖子。
I'm trying to solve this equation:
3t^3-2t+5=0 using the solve function
solve(3t^3-2t+5=0,t)
but when I type t= to solve it, it doesnt give me an answer, just t= the black box
And yes, I am using the Boolean in the equation and in solve so I honestly don't know what's wrong? It won't give me the answers for any solve questions!
Please help ASAP!
Thanks in advance
#2 已发布: 2014/11/23 01:51:32
Mike Kaganski
Mike Kaganski
184个赞,共434个帖子。
Use 3*t, not 3t
С уважением, Михаил Каганский
#3 已发布: 2014/11/23 06:46:27
brotjob
brotjob
7个赞,共71个帖子。
Use 3*t, not 3t
You are not familiar with Smath. The * is inserted automatically when typing.
You (critzker) should use the Maxima plugin, which is part of the portable version. See example below.
#4 已发布: 2014/11/23 07:18:47
Mike Kaganski
Mike Kaganski
184个赞,共434个帖子。
Are you sure?
Just try to paste the OP code to SMath, and see that 3t is inserted as is, not like "3*t". The thing you mention only applies to interactive typing. OP hasn't specified the method he used in the first place.
If used properly, everything works without maxima:
solve((3*t)^3-2*t+5≡0,t)=-0.6132
#5 已发布: 2014/11/23 16:57:52
brotjob
brotjob
7个赞,共71个帖子。
sorry I missed the square three which makes everything much easier.
#6 已发布: 2014/11/23 21:06:55
Mike Kaganski
Mike Kaganski
184个赞,共434个帖子。
I'm afraid I didn't understand your problem the first time.
I suppose you do the following:
type "solve(3t^3-2t+5=0,t)"
go to new line
type "t="
and wait for the answer.
That's not correct. solve is not a procedure that modifies its argument t; it is a function that returns a number, ant that number may (or may not) be assigned to a variable.
You need to have the following:
"t:=solve(3*t^3-2*t+5=0,t)"
then your "t=" will give you the answer (in this form, it will be 2.743).
#7 已发布: 2014/11/24 04:41:10
brotjob
brotjob
7个赞,共71个帖子。
You should definitely use Maxima since the Smath solver misses the complex solutions.
