1页(12条)
Show the Orignal Units in Table Region - Show the original units in the Table instead of the basic units of the International System - 消息
Thanks Sergio:
You made me remember the solution that Martin Kraska gave me, but I can not put a header on it.
Do you have any suggestion?
Units_Table_r2.sm (15.19 KiB)已下载 1412 次。
WroteWill it be possible?
I prefer the way we did in 1987, collecting piles of fluids information.
Units_Table Preference.sm (12.43 KiB)已下载 1406 次。
WroteI thought about this (string manipulation)
but num2strtransforms into fractions
Use var2str() from CustomFunctions instead
Thank you very much to everyone for your help,
I already managed to make the table as I required it.
Units_Table_r3.sm (9.19 KiB)已下载 1420 次。
2位用户喜欢此帖子
Thanks Carlos: gorgeous
CBG,
Using the unit summary to convert units back to original units doesn't work for temperature conversions. What you are doing with the units summary assumes the conversion is a factored multiplier. It works great for everything except temperature (or any other unit doesn't scale by a factored multiplier).
WroteMaybe try something other than 20 deg?...
You are quite right and there are two things here
1. As it looks, the °C can't be made user.
The unit system is grounded on 'K', bloody pest to me.
2. The other thing is the Shadow in context, a real bug.
It worked fine from Carlos original [by what coincidence ?]
Not changing the context, context reproduces. Changing context
and the all thing °C gets freaked. I observed that many times
in Smath. In fact, very problematic.
Thanks for this wise observation.
Table Region Carlos.sm (10.6 KiB)已下载 1359 次。
1页(12条)
