IF function error
IF function error - IF function not working, giving an error - Messages
#1 Posted: 2014/9/4 14:18:07
Ernesto
Ernesto
13 likes in 74 posts.
After updating to the new version, none of my "if" functions are working. I get the following error:
"Method not found: 'System.String Smath.Manager.UnitInfo.GetCurrentUnitName(System.String)'."
Anyone else have this issue?
if_bug.sm (2.34 KiB) downloaded 1106 time(s).
#2 Posted: 2014/9/4 17:11:29
2,326 likes in 4,013 posts.
Ernesto, looks like you have some outdated plug-ins. Please open Extensions Manager update installed plug-ins.
Regards.
#3 Posted: 2014/9/4 17:53:26
Ernesto
Ernesto
The Extensions Manager only gives the option to enable or disable the plugins. I don't see how I could delete or update any of the plugins.
I even tried uninstalling and installing Smath Studio again, and the same error appears.
#4 Posted: 2014/9/6 13:33:42
Ernesto, Extensions Manager allows to update plug-ins.
Please see attached image. Select Online gallery and see the list - available updates shown in violet.
#5 Posted: 2014/9/6 14:49:25
Ernesto
Ernesto
It wouldn't update. I had to uninstall, as well as delete the \Users\[user name]\AppData\Roaming\SMath directory, then reinstall for it to work.
Everything is working now
