Operation with units xy2pol
Operation with units xy2pol - 消息
#1 已发布: 2016/6/5 00:07:03
Basile
Basile
8个赞,共172个帖子。
The xy2pol looks that still has problems with units:
Basile
#2 已发布: 2016/6/5 13:34:47
983个赞,共6,866个帖子。
#3 已发布: 2016/6/5 13:53:42
Basile
Basile
8个赞,共172个帖子。
Jean,
In your example:
The Magnitude (length) and The Angle (angle) in polar coordinates have different units. The rad is not a common unit. It is not correct.
In my example:
Look again please:
This was solved in recent upgrade by Andrey but apparently remains in the xy2pol.
http://en.smath.info/forum/yaf_postst7552_Units--Operation-cannot-be-performed.aspx
Basile
#4 已发布: 2016/6/5 15:14:46
983个赞,共6,866个帖子。
Better be in harmony wth the maths and Smath.
There is nothing to look gain, Smath is OK.
For sure they have different units: one is in "UnitGraph" the other is in "rad"
YES: rad is correct, rad is the maths unit in trig approximations as well as in official tables.
If you want °: convert by appending ° in the Smath result
#5 已发布: 2016/6/5 17:22:05
Basile
Basile
8个赞,共172个帖子。
Jean,
1.
Please go previously and see the picture.
"rad" is the unit for both the magnitude and angle.
There is ONE placeholder for ONE unit.
YES: rad is correct, [YOU JUST SAID THAT ONE IS LENGTH THE OTHER ANGLE!!!] rad is the maths unit in trig approximations as well as in official tables.
2.
In this specific set of applications I have no interest in "numerical MathEMATICS". I use units. Thank you.
Basile
#6 已发布: 2016/6/5 17:38:16
Mike Kaganski
Mike Kaganski
184个赞,共434个帖子。
@Basile,
Just show what you are trying to describe verbally
Not that it would convince anyone who doesn't wish, though.
С уважением, Михаил Каганский
Davide Carpi 2016/6/7 17:28:00
#7 已发布: 2016/6/5 17:52:10
Basile
Basile
8个赞,共172个帖子。
Mike,
The xy2pol does not work when units are included:
Do we agree?
When eventually it is working:
The units of the "Magnitude" and the units of the angle, (for the case of complex numbers here), will be different.
Note: I see you got W(att) how?
I see that you have a semicolon ( ; ) I have a comma (,).
Re(S);Im(S) versus Re(S),Im(S)
Basile
#8 已发布: 2016/6/5 19:26:10
1,139个赞,共1,805个帖子。
Something like that?
Notice that atan2 ins't in SMath, which is more correct than atan for this functions (see http://www.mathworks.com/help/matlab/ref/atan2.html for example).
Davide Carpi 2016/6/5 19:28:00
#9 已发布: 2016/6/5 19:55:50
Mike Kaganski
Mike Kaganski
184个赞,共434个帖子。
Mike,
Do we agree?
Yes we do
引用
Yes, that's what I show in my screenshot, that uses ≡ instead of =, just to show the desired result: seeing is better than reading.
引用
Now I suppose it's apparent: Ctrl+= and manually make system with desired result
引用
Russian locale default settings
#10 已发布: 2016/6/5 19:57:34
983个赞,共6,866个帖子。
In this specific set of applications I have no interest in "numerical MathEMATICS". [Basile]
From A...Z, Smath is a numerical math tool as any other CAS and including your specific application.
xy2pol result is a vector of two components that need no unit as they are implicit. Extract each
component and append a dead unit decoration for clarity to yourself and the reader.
#11 已发布: 2016/6/5 20:03:39
Mike Kaganski
Mike Kaganski
184个赞,共434个帖子。
atan2.sm (35.42 KiB)已下载 1316 次。
#12 已发布: 2016/6/5 20:58:58
1,139个赞,共1,805个帖子。
Hi Mike. I prefer this other, but have some round inconvenients:
未找到文件。未找到文件。
#13 已发布: 2016/6/5 21:04:35
Mike Kaganski
Mike Kaganski
184个赞,共434个帖子。
I guess that with the new try function samebody can make a good one atan2.
But with try, it won't differentiate again.
#14 已发布: 2016/6/5 21:10:02
1,139个赞,共1,805个帖子。
Oh, I think that this happen only to me :-). Not very sure that try don't accept diff.
So, this with numerical optimization must to be the best solution (until atan2 not be in SMath):
#15 已发布: 2016/6/5 21:24:33
Mike Kaganski
Mike Kaganski
184个赞,共434个帖子。
It's a good option, and only ~30% slower.
#16 已发布: 2016/6/6 10:11:40
983个赞,共6,866个帖子。
Like this Alvaro: look for the Matlb code in the f(x) menu,
look for mwatan2 ... if you have in your version: then go
Maths atan2.sm (10.93 KiB)已下载 1381 次。
