Objected Oriented Programming
Objected Oriented Programming - Messages
#1 Posted: 2023/1/18 20:57:31
Artiom Lisin
Artiom Lisin
0 likes in 6 posts.
Hello!
Brand new to SMath, and I was curious to know if there was a way to simulate creating objects with properties etc. For example, I have a car object that has a speed it's moving at and its weight.
#2 Posted: 2023/1/18 21:35:14
1,106 likes in 1,784 posts.
Hi. Something like this?
obj_set_get.sm (11.63 KiB) downloaded 1099 time(s).
sergio 2023/1/19 07:18:00, Mark R Harris 2023/1/20 04:09:00
#3 Posted: 2023/1/18 21:43:15
Artiom Lisin
Artiom Lisin
0 likes in 6 posts.
Hey Alvaro, that is really cool, I didn't know you could do that in SMath. Thank you
#4 Posted: 2023/1/19 15:33:01
Artiom Lisin
Artiom Lisin
0 likes in 6 posts.
Hey Alvaro,
I was testing out your methods with the inclusion of loops and it seems that I can't create a variable beforehand and assign it, it has to be empty. Do you know a way around this?
This is ultimately what I am trying to do with these functions, where I can get a mutable array of "Zones", each with their own properties (ie. area, x/y location etc.)
For reference I read through this thread as well: https://en.smath.com/forum/yaf_postst23278_String-to-Variable-Name--str2var.aspx
and tried some of the solutions posted on there but to no avail.
#5 Posted: 2023/1/19 16:28:07
Artiom Lisin
Artiom Lisin
0 likes in 6 posts.
I figured it out, just don't know a way around it. Since I'm calling str2num(output_i), it's giving me the value of that expression and not the variable itself.
#6 Posted: 2023/1/19 17:22:47
Yep. You need to call str2num at the worksheet level. Something like this
obj_set_get.sm (18.86 KiB) downloaded 1045 time(s).
Also, I'm go to modify the code for accept set or collections.
#7 Posted: 2023/1/19 21:32:59
597 likes in 1,377 posts.
Jean's reply is not corresponding with question.
This algorithm is not creating an object.
It is only finding index of a key in data.
Alvaro 2023/1/19 22:06:00, Mark R Harris 2023/1/20 04:11:00
#8 Posted: 2023/1/19 22:08:17
Thanks.
Updated.
obj_set_get V2.sm (46.64 KiB) downloaded 1065 time(s).
obj_set_get V2.pdf (154.36 KiB) downloaded 610 time(s).
overlord 2023/1/20 00:05:00, Mark R Harris 2023/1/20 04:12:00
#9 Posted: 2023/1/20 13:57:13
Artiom Lisin
Artiom Lisin
0 likes in 6 posts.
Thanks.
Updated.
This is incredible work, it would be really cool to see this kind of feature built-in to SMath in the future.
#10 Posted: 2023/1/20 17:30:40
1,441 likes in 2,932 posts.
mod: Deleted since it was off-topic.
@Jean: please stay on topic.
#11 Posted: 2023/1/20 21:50:59
Artiom Lisin
Artiom Lisin
0 likes in 6 posts.
Thanks.
Updated.
I"ve been absolutely loving using this! Is there a way to disable the historical value saving? I'm trying to override some values rather than keep a record of them, I was thinking of going through a loop that check to see if the second column is zero and making a new submatrix without that row and calling it recursively until there are no 0 values left, however that presents a future problem when the value I want to set is 0. Is there a way around this?
#12 Posted: 2023/1/20 23:32:36
... Is there a way to disable the historical value saving? ...
Hi. A version without values history.
obj_set_get V3.sm (53.66 KiB) downloaded 1104 time(s).
#13 Posted: 2023/1/21 03:23:13
1,544 likes in 1,859 posts.
Maybe this plugin will be useful: Wiz Functions
It contains a set of functions for manipulating key and value pairs.
