1 Pages (5 items)
Boolean less than and greater than - difficulty using < and > - Messages
hi there,
I've just started using smath for a uni project,and i am trying to get an answer not to exceed a particular amount, i was hoping that you guys might have a method, tips or tutorial to explain it.
thanks in advance
thanks in advance
Hi Mr Green,
You can use booleans and programming functions (if/else) to check if your answer fit your target.
On the wiki you can found an example (here) and also a lot of tutorials and examples about using SMath Studio.
Moreover, there are plugins to extends these features:
- CF Label plugin
- Functions' Extensions
- CF Label plugin
Hi Mr Green,
- CF Label plugin
- CF Label plugin
Wrotei am trying to get an answer not to exceed a particular amount
you might just use [MATH]Min(whatever_you_get;upper_limit)[/MATH]. The lowercase function [MATH]min(#)[/MATH] works as well but just takes a single vector or matrix argument.
Davide Carpi 2014/2/19 14:35:00
1 Pages (5 items)
