Area of irregular polygon
Area of irregular polygon - 消息
#1 已发布: 2015/2/20 14:54:13
vivsets
vivsets
0个赞,共2个帖子。
Hi friends,
I am newbie to Smath studio and I am trying to find area for irregular polygon. I have input the coordinates in a matrix and created a small function to find the area using coordinate geometry. But i am getting an error as the function is not evaluated. if I run the function for a square it works fine. Can somebody help me what is wrong with my function? I have attached the file for reference.
Thanks
Vivek
Page1.sm (5.64 KiB)已下载 1794 次。
#2 已发布: 2015/2/20 16:15:43
Gerry_Bush
Gerry_Bush
12个赞,共14个帖子。
Hello Vivsets,
I think your formula is trying to reference one more row than you need to (outside your matrix). Try rows(X)-1 in your for loop.
Gerry Bush
Page1-1.sm (5.7 KiB)已下载 1772 次。
#3 已发布: 2015/2/20 18:03:56
1,443个赞,共2,936个帖子。
If you are interested, in the Extensions Manager (Tools > Plugins > Examples [Local Storage > Online Gallery]) there is a worksheet dedicated to to polygons' properties - just to not reinvent the wheel
#4 已发布: 2015/2/20 19:36:54
vivsets
vivsets
0个赞,共2个帖子。
Thanks Gerry and Davide for your replies.
Gerry I fixed the function based on your answer and it works fine.
Davide your example sheet is awesome. You are right there is no point in reinventing the wheel. I will go through it in detail and put it in use in my future development of sheets.
