contents.sm
contents.sm - Reference book of SMath 98.6484 from 2017+11+18+SMath+98.6484+with+Plugins - 消息
#1 已发布: 2017/11/28 03:50:14
electricescu
electricescu
0个赞,共8个帖子。
引用
SMath Studio Handbook 0.98.6398
$Author: mkraska $
$Date: 2017-08-01 12:34:12 +0200 (Di, 01 Aug 2017) $
not works
not works all links from all ms files from book directory.
exists style diferences
from
Reference book of SMath Studio
to
Reference book of SMath Studio works
i have windows 7
remember mathematics
#2 已发布: 2017/11/28 19:45:45
1,362个赞,共2,276个帖子。
What does mean "does not work"?
You need to be in the settings directory or installation directory for the interactive book to work. This is a bug or feature in the interactive book mechanism.
What do you mean by style differences? What is the particular problem? Please add screenshots or the like (use the paperclip button in the forum post editor to attach files or images)
#3 已发布: 2017/11/28 20:59:23
electricescu
electricescu
0个赞,共8个帖子。
differences are in codes source.
is missing <>build-in="true" on second file.
here is an example:
1
Programmbedienung
Program Operation
未找到文件。未找到文件。
#4 已发布: 2017/11/28 21:14:02
electricescu
electricescu
0个赞,共8个帖子。
there are no clickable links
is very possible to be just a small trouble.
tomorow i will make a movie to see when i click on texts of links is nothing hapen, only focus on there texts
#5 已发布: 2017/11/29 03:03:11
325个赞和1个踩,共2,052个帖子。
I think that your problem was that in tha Martin's Handbook you have to pres CTRL+Left mouse click and in the Reference book made by Andrey (goes with SMath) it is enough Left mouse click to open other worksheets. Actually, I think there is still no simple way to make these Handbooks like Andrey did.
Martin Kraska 2017/11/29 04:54:00
#6 已发布: 2017/11/29 04:53:31
1,362个赞,共2,276个帖子。
Radovan, thanks for pointing this out. I had forgotten about this. The behaviour of the links depends on the read-only status of the handbook files, at least this was so some years ago. I considered the handbook browser being just a workaround for a real help system. But as you see, workarounds can last for long time.
If that is really the source of the problems reported above, I see two options to avoid it:
- I could write a script to set all files read-only and then test if this leads to functional restrictions of the handbook pages.
- The user could care the instructions on the main handbook page.
Radovan Omorjan 2017/11/29 12:34:00
#7 已发布: 2017/11/29 12:43:36
Hello Martin,
As you say, ...workarounds can last for long time...
I was expecting that, after such a long time, your Handbook would have worked (regarding to the links and the menu items Home, Back, Copy) like the other Reference book (made by Andrey long time ago). Unfortunately, it is still in the workaround state. As I mentioned many times, your Handbook should be the main Reference SMath book (and a real Help system) at the moment IMHO. Why this is still not the case, I do not know.
