1页(10条)
Double pendulum - 消息
已编辑 2026/9/20 10:09:28
Hi Valery. The system is coupled. This is a way to solve it.
double_pendulum_lagrangian.sm (122.44 KiB)已下载 340 次。
double_pendulum_lagrangian.pdf (637.78 KiB)已下载 280 次。
2位用户喜欢此帖子
Yes, that is correct; I previously reported on the limitations regarding the systems.
The algorithm does not currently classify the task, so issues may arise with complex problems that the current method cannot solve. It might produce a plausible-looking solution that does not actually address the problem at hand.
If mathematics is a tautology, then life must be one too. That joke reminds me of the one a plant process engineer played on me when I went to get the bourdon gauge I was supposed to install. Without a word, he handed me a brown box. That was when I have the bad idea of asking what was inside. His answer was that it contained a mechanical device that measures fluid pressure using a curved, flattened metal tube that straightens as internal pressure increases, driving an indicator needle across a calibrated dial.
The RKA function includes the necessary procedures to solve hard coupled systems.
double_pendulum_RKA.pdf (483.53 KiB)已下载 273 次。
double_pendulum_RKA.sm (43.57 KiB)已下载 339 次。
2位用户喜欢此帖子
Thanks, Alvaro!
But I cannnot create five f(t) plots:
Potential energy of pendulum #1
Kynetic energy of pendulum #1
Potential energy of pendulum #2
Kynetic energy of pendulum #2
Sum of energies for the verify the model and ODEs solver. Must be const.
Help please!
Help please!
已编辑 2026/10/8 11:18:52
Hi Valery. This is a way. You can plot the time in T versus U, K or U+K. The plot in the figure shows that the energy is constant. In this case also, the total energy is the hamiltonian.
double_pendulum_RKA.sm (49.21 KiB)已下载 197 次。
已编辑 2026/10/9 01:19:29
ioan92 2026/10/10 18:59:13
Butterfly_Effect_Example.pptx (999.46 KiB)已下载 119 次。
Hi Alvaro & Valery,
I enjoyed the matematical results of yours developements, without following all details.
I propose you a problem, dealing with the Butterfly Effect on a double pendulum - after some cycles, the 2 pendulums becoms distinct. Attached there is a simple gif file
Hi Alvaro & Valery,
Hi Ioan. Something like this.
double_pendulum_RKA Butterfly Effect.sm (50.58 KiB)已下载 194 次。
5位用户喜欢此帖子
Victor 2026/10/16 07:34:28, Valery Ochkov 2026/10/10 05:45:18, sergio 2026/10/10 08:51:15, ioan92 2026/10/10 12:34:44, Вячеслав Мезенцев 2026/10/10 16:02:19
Ooo it's wonderful!!!
My dumb explanation is that time delay generate between the 2 instances generate different precision in the solution graphics and hence the graphical difference (?).
Alvaro - All my thanks for your proverbial attention,
Have a nice WE,
Ioan
Have a nice WE,
Ioan
Alvaro 2026/10/10 19:03:11
1页(10条)
