1页(4条)
Issue with finding derivative - 消息
I was just playing with the software and it looks promising, but I cannot say that it is reliable right now. While checking out differentiation option I found an error. On the screen you can see 3 different calculations and second one gives wrong result.
Hello. Thank you for the report.
This error in symbolic module of the SMath Studio was already found and fixed:
New version of the program will be available on the end of February.
Hello there,
You did a great piece of work here, and I think I found out a problem.
Sorry but I can't post an image of it.
I compute the following
derivative of (exp(1/x)) and derivative of (exp(x^-1)) I'm expecting the same output but I got for the first one :
-exp(x)/x^2 and for the second one -exp(1/x)/x^2.
The version I'm using is windows 0.78 b3347 and I reproduced it also on the handheld version.
Thanks in advance,
C.
Thanks in advance,
C.
Thanks for the report. I've got the similar finding from the russian user of SMath Studio this week. Error reproduced, will be fixed asap.
1页(4条)
