1页(3条)
Ignore units or Error: Result is above max.allowed positive number - 消息
Hello community,
with activated units the evaluation of a expression in my sheet is aborted with the error:"Result is above max.allowed positive number". If units for the sheet are deactivated the expression is evaluated, but the result is different.
units deactivated:
Changing the evaluation to numeric does not change the behaviour - I followed the discussion here: Result-is-above-max-allowed-positive-number.
Do you have general advice to resolve the issue of the aborred evaluation of the expression?
If necessary I would send smath-file via Email (work in progress for a publication*).
Bye
radex
Ps.: @community here - thank you for smath and all the great plugins
*will late be published as a tutorial
units deactivated:
Bye
radex
Post the work sheet, that will help.
on't use unit from the menu. Define separately,
plug in the place holder.
Without the worksheet is really hard to understand where may be the issue...
Have you tried to force a partial numeric evaluation in either the numerator or the denominator using eval(#)?
WroteDo you have general advice to resolve the issue of the aborred evaluation of the expression?
1页(3条)
