1页(4条)
[Maxima Plugin] is a custom Maxima function call-able in SMath - Can SMath call a custom Maxima function? - 消息
I have defined a function in Maxima but am unable to call it in SMath... I've searched around and tried a bunch of different syntaxes buy am still new to this so if it does indeed work I couldn't get it going... Any help would be appreciated.
Attached are the Maxima .mac file and the SMath file attempting to call it.
func_gradient_divergence_curl.7z (329 B)已下载 705 次。
calling custom Maxima function.sm (4.01 KiB)已下载 1271 次。
WroteAny help would be appreciated.
Forget what does not work outside of native Smath
Maths Grad_Div_Curl.sm (12.21 KiB)已下载 1345 次。
WroteI have defined a function in Maxima but am unable to call it in SMath... I've searched around and tried a bunch of different syntaxes buy am still new to this so if it does indeed work I couldn't get it going... Any help would be appreciated.
It seems that there is a conflict with the vector package (load(vect) is executed at maxima startup in the plugin). If you remove that call, then your macro is loaded. I only tried this in wxmaxima. See Insert> Maxima> Log> wxm to see what the plugin does at startup.
![2018-05-22 18_24_27-SMath Studio - [lcm.sm_].png](/zh-Hans-CN/files/Download/MLoM7B/2018-05-22-18_24_27-SMath-Studio---[lcm.sm_].png)
1页(4条)
