1 Pages (5 items)
[SS-3567] File corrupted after using region protection option - Messages
I used protection regions on my smath sheet. Everything went fine until I close the sheet and try to reopen it. I can't expand areas no more (no "+" or "-" available anymore at the begining of the area), nor can I run calculations...
The file seems corrupted. It weights only 20kB...
Someone help please!
File is available here :corrupted file.sm (20.13 KiB) downloaded 1139 time(s)..
Thanks a lot
Thanks a lot
Confirmed and reproduced; (also, reproducible using copy and paste on opened worksheets).
Unfortunately everything in the protected area is lost (not saved, hence not recoverable).
Bug reported as SS-3567.
Thank you for having a look at it anyway.
WroteThank you for having a look at it anyway.
Thank you for reporting; as posted in the BTS the issue is fixed now and will be part of the next release.
1 Pages (5 items)
.png)
.png)
.png)
