Inversing Matrix in MES algorithme
Inversing Matrix in MES algorithme - Problem with inversing Matrix - 消息
#1 已发布: 2018/8/27 14:20:21
Krystian
Krystian
0个赞,共2个帖子。
I have an issue when I try to inverse matrix without defining new variable Smath does a calculation, but when I try to define new variable with value of inversed matrix smath stucks in calculation. I attached a file, hope You can help me
RAMA3.sm (52.97 KiB)已下载 1359 次。
#2 已发布: 2018/8/27 15:34:15
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Try the eval () function
#3 已发布: 2018/8/27 16:41:22
127个赞,共342个帖子。
By opening your file, errors correspond to two incomplete formulas. If you delete the two missing terms (one for formula) and if you set the rating to "numeric" (in your file The two formulas are set to "symbolic"), everything will work correctly.
[albumimg]1510[/albumimg]
[albumimg]1511[/albumimg]
Sergio
#4 已发布: 2018/8/27 20:27:56
983个赞,共6,866个帖子。
Few things are not defined. Doctored in red, red is numeric.
Observe ... diag(v)
RAMA3.sm (68.17 KiB)已下载 1352 次。
#5 已发布: 2018/8/28 03:03:20
Krystian
Krystian
0个赞,共2个帖子。
Formulas was incomplete because of having problems with calculating equation. Your solutions helped me. Thank You everyone, thread's exhausted
