element belongs to a collection
element belongs to a collection - collections - 消息
#1 已发布: 2019/7/12 08:26:36
Jadalbert
Jadalbert
0个赞,共17个帖子。
I have the question like this:
Is it possible to obtain a result depending on whether the variable belongs to the collection?
I mean the construction:
if x "belongs to" {1, 2, 4, 8} then x=0 else x=111
or even
if x "belongs to" {1, 2, 4, 8} else if x "belongs to {33, 45, 11) then x=99 else x=111
Thanks for an any response.
Jadalbert
#2 已发布: 2019/7/12 09:27:29
Arie
Arie
94个赞,共285个帖子。
Perhaps something like this?
elementsbelongs.sm (4.51 KiB)已下载 1161 次。
frapuano 2019/7/12 16:24:00
#3 已发布: 2019/7/13 10:45:58
983个赞,共6,866个帖子。
This is too vague for real answer.
Yes, you can locate elements of an array that belongs as well to another array.
Please, visit an extensive example, posted next few minutes:
"Locate in array"
In simple one array is much simpler, please let know if desired.
Cheers.
#4 已发布: 2019/7/13 11:10:28
Jadalbert
Jadalbert
0个赞,共17个帖子。
Thank You both for help. I tested both example and it works. But I dont understand how can I add new line to method (function) cases()? If it is the function cases(), may be I'm wrong. I mean:
x := {1 if ...; 2 otherwise
#5 已发布: 2019/7/13 19:29:29
983个赞,共6,866个帖子。
But I don't understand how can I add new line to method (function) cases()?
... like this
once you have if/otherwise [Cases], click right hand most place holder,
coma twice for one more if... again coma twice like before, DIY.
Cheers.
#6 已发布: 2019/7/15 08:29:29
Jadalbert
Jadalbert
0个赞,共17个帖子。
... like this
Cheers.
Ok, it works. But, I must use SEMICOLON twice. May be it is the same as coma (or comma) in real english. Im from Poland and my English is from school.
Anyway - thank You for help.
Jadalbert
#7 已发布: 2019/7/15 08:41:38
1,443个赞,共2,936个帖子。
That's because the more correct answer about arguments or decimal separators would be "press your argument separator" or "press your decimal separtor", since you can customize them in Tools > Options
