1页(5条)
Hardy Cross / Moment Distribution Method - 消息
Has anyone performed the Hardy Cross / Moment Distribution Method on a continuous beam in SMath? Are there any examples of this on the forum?
Best regards,
Best regards,
WroteHas anyone performed the Hardy Cross / Moment Distribution Method on a continuous beam in SMath?
Hans, no much audience for that one !
My only competence is monkey see monkey do.
... not finished yet that demo.
Cheers ... Jean.
Page1 Hardy-Cross.sm (50.97 KiB)已下载 1386 次。
Hi, I do that not by computation but graphically on CAD by moving the "baseline" which is substracted from an assumed simply-supported moment at each span. For me the advantage is, it's very visual so errors are instantly visible, options are also visually obvious, so design decisions can be taken quickly. (I draw parabola in CAD as segments of very very elongated ellipses).
WroteI cant quite visualize the "framework" to set it up if you will.
steps are the missing links ... out of the blue !
1页(5条)
