RC: SMath Studio 0.97.5301 (07 July 2014)
RC: SMath Studio 0.97.5301 (07 July 2014) - 消息
#21 已发布: 2014/7/19 04:23:19
1,362个赞,共2,276个帖子。
This is a decimal separator issue. If you use the period as dec sep, then units with subscripts display correctly (SS-173)
#22 已发布: 2014/7/19 05:46:57
LitvincevYV
LitvincevYV
1个赞,共7个帖子。
thanks
#23 已发布: 2014/7/25 18:39:00
Ryan Freund
Ryan Freund
20个赞,共339个帖子。
I seem to have a problem with "Areas"
Try this:
1. Type Text (call this top text)
2. Insert Area below text
3. Type in area (call this "in area text")
4. close area (note that this does not include "top text")
5. Open area
6. Move top area line above the "Top Text" so that it is not inside the area
7. Close area
8. Notice that the "top text does not close into the area"
9. However, Save the file, close SMath and restart the program. Open the file and all is fine.
Anyone else has this issue?
#24 已发布: 2014/7/26 01:58:47
325个赞和1个踩,共2,052个帖子。
There are already known problems with area region (see this in Bugs SS-171 for instance). Moving area handlers is an especially risky operation. SMath can crash easily than.
