How to display string element of the matrix in Smath Viewer? - 消息
Hello wb.c
Hola Alvaro
I already reinstalled Smath Studio and the viewer still doesn't work for me.
The EXE file that wb.c publishes if it works for me, it would be interesting
to also have the SM file to be able to compile it to EXE, and check if it works.
Thanks a lot
Hola Alvaro
Thanks a lot
Hello wb.c
Thank you very much for the file.
I compiled it to an EXE file and it worked perfectly fine.
I did a test again generating the file myself, and now everything works fine.
Thanks a lot
Thanks a lot
WroteHello wb.c
Thanks a lot
wb. c and Carlos,
I suggest posting this in the bugs log. The idea of the viewer is that the user would not need the file or to re-compile the EXE.
