1页(5条)
Nightly build: SMath Studio 0.96.5146 (02 February 2014) - 消息
Nightly build: SMath Studio 0.96.5146 available
Important notes
- Custom Regions plug-ins created for previous versions of SMath Studio will not work. Please contact developers of such plug-ins and ask them to update plug-ins. Sorry for the inconvenience!
In the class inherited from IPluginCustomRegion change:to:bool IPluginCustomRegion.IsCurrentClipboardSupported { get { IDataObject iData = Clipboard.GetDataObject(); return iData.GetDataPresent(DataFormats.UnicodeText); } }string[] IPluginCustomRegion.SupportedClipboardFormats { get { return new string[] { DataFormats.UnicodeText }; } }
It is also required to add the following field (where tag name for your region must be specified instead of "combobox" text):string IPluginCustomRegion.TagName { get { return "combobox"; } }
In the class inherited from RegionBase signatures of the methods:changed to:public override bool Copy() public override bool Paste()public override bool Copy(IClipboardManager clipboard) public override bool Paste(IClipboardManager clipboard)
So, you don't need to use System.Windows.Forms.Clipboard anymore. Just use clipboard object from method argument. - No official portable version will be available for this release.
Latest changes (against SMath Studio 0.96.4909)
- Complexities in sys(), line() and matrix() resizing fixed;
- Fixed issues of opening Dynamic Assistance list after collapsed Area(s);
- Handling of broken plug-ins on application loading and on plug-ins installation improved;
- Backspace handling improved when cursor is on the worksheet;
- Inserting number before variable automatically sets multiplication operator between those number and variable;
- Fixed unhandled exception on copy/paste of empty placeholder;
- German units names added;
- Added support for text entries and descriptions of not installed language;
- [DEV] Added API to export worksheet per pages;
For example, see: https://smath.info/svn/public/plugins/PdfFileType/ - [DEV] Correction to RegionHolder in order to allow changing size of the region by resizing of canvas (structure inside RegionHolder);
- Code certificate updated;
- Language files updated;
- Refactoring and optimizations.
Download
- Desktop Windows (desktop computer with Windows OS):
SMathStudioDesktop.0_96_5146.Setup.msi (Date: 02.02.2013. File size: 1.73MB) - Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_96_5146.Mono.tar.gz (Date: 02.02.2013. File size: 944.39KB) - last version of Mono distributive required!
7位用户喜欢此帖子
Martin Kraska 2014/2/2 07:40:00, ioan92 2014/2/2 08:54:00, Radovan Omorjan 2014/2/2 09:07:00, Вячеслав Мезенцев 2014/2/2 09:27:00, IVR 2014/2/3 05:13:00, sergio 2014/2/3 13:58:00, Davide Carpi 2014/2/2 08:01:00
Andrey, thanks for the update.
For testing I recommend to use the Linux version. As usual it can be used under Windowsm as portable version when an empty file "portable.version" is added to the installation directory. Then you can keep all extensions and settings separate from your standard installation.
An unofficial portable version will certainly be available, depending on upgrade progress of custom regions.
Unfortunately, the Maxima plugin is affected by API changes as well, even if not providing a custom region, access to the insert menu or custom windows seem to be problematic as well.
FYI: I've just added a spoiler about what to be done to update Custom Regions related plug-ins.
2位用户喜欢此帖子
The following plug-ins updated to support SMath Studio 0.96.5146:
- Combobox Region
- Checkbox Region
- Modeller Region
- Export to PDF
2位用户喜欢此帖子
- Modeller Region
Any hint on how to use it? How about gallery example passwords?
Might be really interesting and powerfull stuff...
Radovan Omorjan 2014/2/2 16:43:00
1页(5条)
