Calculated values not displayed
Calculated values not displayed - Calculated values not displayed - 消息
#1 已发布: 2018/10/12 09:29:38
Ramon Tavarez
Ramon Tavarez
2个赞,共12个帖子。
Hi.
After installation of v0.99.6839 the calculated values are not displayed.
I uninstalled and reinstalled Smath v 0.99.6839, and the problem persist.
I unsinstalled and reinstalled a previous version and the problem is still there
(when the previous version was installed and runnig there was no problem).
images of sample and computer info attached.
Thanks for the support.
未找到文件。未找到文件。
#2 已发布: 2018/10/12 09:35:45
Arie
Arie
94个赞,共285个帖子。
Can you attach the .sm file in question?
#3 已发布: 2018/10/12 09:49:13
Ramon Tavarez
Ramon Tavarez
2个赞,共12个帖子。
Here the file.
Created with v 0.99.6858
issue example.sm (8.93 KiB)已下载 1362 次。
#4 已发布: 2018/10/12 10:18:03
127个赞,共342个帖子。
the problem is not confirmed with Win7 pro and SMath v0.99.6858.
#5 已发布: 2018/10/12 10:28:39
Ramon Tavarez
Ramon Tavarez
2个赞,共12个帖子。
The issue is confirmed on Win 7 Pro 32 bit since v 0.99.6671
#6 已发布: 2018/10/12 11:43:31
Arie
Arie
94个赞,共285个帖子。
Looks ok on my machine. Did you happen to turn off Auto Calculation? What happens if you press F9?
#7 已发布: 2018/10/12 11:51:16
Ramon Tavarez
Ramon Tavarez
2个赞,共12个帖子。
on F9 recalculates manually.
What I need is autocalculation. (I didn´t turn it off)
#8 已发布: 2018/10/12 11:56:11
Arie
Arie
94个赞,共285个帖子。
Correct, I was just trying to determine if you simply needed to calculate the page. The only way I could recreate what you showed is if I turned off auto calculation
If pressing F9 actually showed the values you can turn Auto calculation back on by going to menu bar clicking Calculation -> Auto Calculation.
I'm assuming auto calculation is off because in your screen shot, the last line is actually an assignment. If auto calculation were on, that incomplete assignment would be outlined in red.
#9 已发布: 2018/10/12 11:57:14
1,443个赞,共2,936个帖子。
It is currently enabled?
#10 已发布: 2018/10/12 12:34:36
Ramon Tavarez
Ramon Tavarez
2个赞,共12个帖子。
@Davide: Yes. It displayed as marked (activated option), but still wasn´t working.
@all:
I uninstalled all once again, then cleaned all registers on the system and then reinstalled Smath.
Now everything works as it should work.
(extrange behavior )
Thanks again for your support
Keep working this way.
