Symbolic result for sum(#)
Symbolic result for sum(#) - 消息
#1 已发布: 2020/7/5 19:17:35
1,139个赞,共1,805个帖子。
Hi. sum have an issue for symbolics evaluations.
#2 已发布: 2020/7/5 19:36:36
983个赞,共6,866个帖子。
Just check , Alvaro.
Between yourself and me ... we are old kookoo in those games !
#3 已发布: 2020/7/5 20:51:36
600个赞,共1,381个帖子。
You are correct, bug reproduced.
Definitely there are some issues.
Perhaps it is not only sum related too.
Alvaro 2020/7/6 03:46:00
#4 已发布: 2020/7/6 03:45:56
1,139个赞,共1,805个帖子。
Hi. Thanks Overlord. I don't see these other problem. What make troubles for me is the fact that sum don't returns the symbolic values but numerical approximations, in this case for sqrt(17). I expect to see sum(vec) = 5/sqrt(17) instead the rational showed. I introduce the "x" value just for check if sum have some eval() function somewhere. But then ... ups, another issue simplifying 1+4.
#5 已发布: 2020/7/6 04:00:32
1,362个赞,共2,276个帖子。
sum.sm (11.67 KiB)已下载 1532 次。
Alvaro 2020/7/6 12:49:00
#6 已发布: 2020/7/6 07:17:28
983个赞,共6,866个帖子。
I see no bug ...
NOBUG.sm (30.88 KiB)已下载 1466 次。
#7 已发布: 2020/7/6 12:48:31
1,139个赞,共1,805个帖子。
Hi. Some notes attached.
sum.sm (20.39 KiB)已下载 1472 次。
sum.pdf (66.13 KiB)已下载 833 次。
#8 已发布: 2020/7/7 07:34:39
983个赞,共6,866个帖子。
