Path in window title bar
Path in window title bar - 消息
#1 已发布: 2018/8/17 12:14:57
dio pants
dio pants
16个赞,共180个帖子。
Is it possible to add the file path in addition to the filename in the window title bar?
Or maybe make it a preferences checkbox option.
Often times when using a repetitive calculation, I find that I am working on the one in the wrong folder.
#2 已发布: 2018/8/17 14:54:15
983个赞,共6,866个帖子。
Hard to understand why working the same document in different folders.
To minimize crashing save the same document in the same folder
Save as copy ... alternate between the copy and the not copy .
#3 已发布: 2018/8/19 20:13:21
1,139个赞,共1,805个帖子。
Hi. You can see the Document Directory with the Mathcad Plugin, not in the toolbar but in the SMath document:
