ZedGraph Question
ZedGraph Question - No negative scale markers - 消息
#1 已发布: 2025/2/27 05:52:38
RegRetired
RegRetired
8个赞,共144个帖子。
In the following ZedGraph, there are no major scaler markers in the negative y axis region. Have I missed an important parameter in setting up the graph?
ZEDGRAPH QUESTION.sm (38.86 KiB)已下载 1763 次。
Thanks,
Reg
Reg CurryLoveland, CO
#2 已发布: 2025/2/27 11:54:24
1,139个赞,共1,805个帖子。
Hi Reg. Logarithmic scales do not allow negative values. Therefore, they are not shown on either axis, since both have logarithmic scales.
#3 已发布: 2025/2/27 12:05:45
RegRetired
RegRetired
8个赞,共144个帖子。
Hi Alvaro,
The vertical scale is set to linear.
I fixed the later time values to -300.
Reg
#4 已发布: 2025/2/27 13:32:03
1,139个赞,共1,805个帖子。
Oh, yes! You're right. I see "E" and think in logs. Please modify this parameter:
RegC 2025/2/27 13:54:00
#5 已发布: 2025/2/27 13:54:16
RegRetired
RegRetired
8个赞,共144个帖子。
Hi Alvaro,
Thanks much!
ZedGraph is necessary for any log scales as far as I can tell. I has more options than I can keep track of. :>D
Thanks again,
Reg
