ODE RK Quick Trick
ODE RK Quick Trick - ODE RK Quick Trick - 消息
#1 已发布: 2016/10/27 13:00:54
983个赞,共6,866个帖子。
Hello Radovan and all,
Do you have a trick to manage that system ?
Thanks in advance, Jean
ODE rk Quick Trick.sm (9.15 KiB)已下载 1271 次。
#2 已发布: 2016/10/27 14:46:11
325个赞和1个踩,共2,052个帖子。
Sorry Jean, I do not understand what did you mean by "trick".
Those are three linear first order ODE which are very often found in reaction kinetics. It seems to me that this would be no problem at all in numerical solving of them. Analytical solution should be also obtained by the appropriate method for such system.
Ra
#3 已发布: 2016/10/27 22:48:01
983个赞,共6,866个帖子。
Quite right Radovan about analytical methods.
Read more from former Mathsoft Collabs: Valery and Viktor,
link in the work sheet.
ODE Laplace Kinetic Reaction.sm (47.62 KiB)已下载 1315 次。
Radovan Omorjan 2016/10/28 06:28:00
