1页(4条)
SMath sudden interruption - Unexpected interruption with data lost. - 消息
Hello Everybody,
Sometimes I faced a Smath behavior that I do not know how to interpret.
SMath is totally freezed and data are lost. The received message is:
Thanks for your attention,
Ioan
1.I wonder if somebody else met the same problem.
2.I’m interested about the reason for this artifact?
3.I'd like to know if I had done something abnormal and especially I'd like to know how to avoid this;
Ioan
Never happened to me.
Whatever the issue with license check is, this shouldn't happen.
When you log in there is a procedure for a offline activation, you might try that to avoid this issue.
WroteSMath is totally freezed and data are lost.
ioan92 2024/9/13 20:02:00
Thanks for the advice.
I registrated SMath offline.
Whith this procedure, the admitted registration is valid for max 12 months.
Probably, the procedure has to be repeated each 12 month ? My licence is: lifetime.
Thanks again
Thanks again
That's my interpretation as well (I checked and I have the same options)
ioan92 2024/9/16 15:15:00
1页(4条)
