3D-Scatter Plot
3D-Scatter Plot - How can I plot it - 消息
#1 已发布: 2023/5/5 06:29:56
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
How can I plot 3-D diagram? So for example.
See please the SMath attach!
GTU-Ro-T.sm (383.51 KiB)已下载 1493 次。
#2 已发布: 2023/5/5 08:32:19
983个赞,共6,866个帖子。
1. Arrays dimension do not match.
2. Once doctored, maybe Maxima.
#3 已发布: 2023/5/5 09:25:47
983个赞,共6,866个帖子。
... a bit doctored.
GTU-Ro-T.sm (393.15 KiB)已下载 1458 次。
#4 已发布: 2023/5/5 12:11:50
1,362个赞,共2,276个帖子。
If the Maxima Plugin is an option for you, then just create a n x 3 data matrix and plot it using Draw3D. You find more plot examples in my Handbuch (section 8.1).
GTU-Ro-T_Kr.sm (395.9 KiB)已下载 1455 次。
#5 已发布: 2023/5/5 15:06:56
Dustin Reynolds
Dustin Reynolds
0个赞,共1个帖子。
thank you for your hard work... i am learning Smath because im fed up with ptc bullcrap.
ohh how i wish i had mCad 15 on this computer, but dont have my original disk...plus this is an opportunity to become a better programmer, learning
from all of the work on plug-ins etc...
hopefully we can some day graph a 3d scatter plot which will do what i did years ago with Mcad.
enjoy the clip..i may have smoked too much at that the time i made it.
In response to this Thread...I have a question.. I modified points-joined=false and it works, but how can I get Points instead of little crosses?
Funny Orbits 3.zip (3.61 MiB)已下载 519 次。
#6 已发布: 2023/5/5 16:29:48
1,139个赞,共1,805个帖子。
Also you can use a 3x2 matrix for rotate and project 3-D data into 2-D for plot it.
Click to enlarge
GTU-Ro-T.sm (397.19 KiB)已下载 1461 次。
#7 已发布: 2023/5/5 17:16:54
983个赞,共6,866个帖子。
... differently by doing what's wanted.
3D Plot.sm (61.83 KiB)已下载 1404 次。
3D Axes System XYZ User Explorer.sm (52.17 KiB)已下载 1469 次。
3D Axes System Parametric Explorer.sm (21.02 KiB)已下载 1419 次。
3D Solid cut by Surface.sm (72.29 KiB)已下载 1450 次。
#8 已发布: 2023/5/5 21:04:08
983个赞,共6,866个帖子。
...project 2D on 3D
Analemma [Project_Anim].sm (33.25 KiB)已下载 1199 次。
Analemma PROJECTION.sm (81.08 KiB)已下载 1439 次。
