Does not display "Unitless"
Does not display "Unitless" - when similar units are divided the result does not cancel the unit - 消息
#1 已发布: 2012/8/11 13:04:58
Maxx
Maxx
1个赞,共8个帖子。
please help and see attached file.
thanks and more power to SMATH!
megamaxx
Andrey Ivashov 2012/8/12 15:38:00
#2 已发布: 2012/8/11 13:15:38
Maxx
Maxx
1个赞,共8个帖子。
i dont know how to post the jpg screenshot of the bug.
please give tip for easier viewing of the concern.
regards,
maxx
#3 已发布: 2012/8/11 13:21:05
325个赞和1个踩,共2,052个帖子。
See this please Attaching files
Regard,
#4 已发布: 2012/8/11 13:27:06
Maxx
Maxx
1个赞,共8个帖子。
Thanks Omorr! already attached the jpeg on my 1st post.
Maxx
#5 已发布: 2012/8/11 13:38:09
1,443个赞,共2,936个帖子。
megamaxx
Hi megamaxx,
you have forgot the unit in the BITE_actual definition (see the attachment)
regards,
w3b5urf3r
P.S. the wiki was updated some time ago for the direct attachments
#6 已发布: 2012/8/11 13:41:10
I tried your example and got the unitless value, as it should be.
Could you attach your *.sm file, please.
#7 已发布: 2012/8/11 13:44:48
1,443个赞,共2,936个帖子。
megamaxx
from wath I can see from your *.sm file, you simply forgot the unit in BITE_actual (see the attachments), but I can't reproduce the issue in your image...
regards,
w3b5urf3r
P.S. the wiki was updated some time ago for the direct attachments on forum
P.P.S. using the "quote" button this topic have returned me 2 times a message like "since this is a moderated forum you need an administrator approvation"
#8 已发布: 2012/8/11 23:56:08
Maxx
Maxx
1个赞,共8个帖子。
w3b5urf3r & omorr,
Thanks I appreciate you guys looking up on this matter.
It's a bit strange for me since the file and the attachment does show the BITE_actual=12 (without the mm) as w3b5urf3r commented.
Apologies for the trouble, I'm having a hard time how to replicate jpeg image right now as I encode my calculation template...hmm, makes me doubt myself in a way.
I'll update you guys if ever I'll bump on this item again.
Best Regards,
megamaxx
#9 已发布: 2012/8/12 03:22:04
1,443个赞,共2,936个帖子。
Hi
I can't replicate the issue but now I can confirm that there is something strange
In the attachments there are:
1) the source of your file as downloaded
2) the source of your file opened by SMath studio and saved on my PC
3) the correct source
I do not know how did your SMath create the script:
mm
regards,
w3b5urf3r
#10 已发布: 2012/8/12 15:35:18
2,344个赞,共4,057个帖子。
组: Super Administrator
Many thanks for the bug report and for troubleshooting!
I've reproduced a bug. See animation for details. Wil fix this.
Best Regards.
Davide Carpi 2012/8/13 08:03:00
#11 已发布: 2012/8/15 07:43:34
Maxx
Maxx
1个赞,共8个帖子。
Andrey & w3b5urf3r, good job on finding the related bug. =)
