1页(4条)
SMath font (v0.98 build 5935) - Standard font display issue - 消息
Dear all,
After installing the most recent SMath version on 2 computers, I notice a difference in font display although all settings are the default ones.
This bothers me because sheets I produce at home are totally messed up when I open them at work...
What could be the reason for this? Absence of certain standard Windows fonts?
Thanks in advance for any feedback!
Jan
Jan
Hello Davide,
Changing my screen size to 100% did the trick (was on 125% - default setting): thank you for your reaction!
Document layout within SMath should be independent from screen size setting, however I'm glad this issue is resolved ;-)
Kind regards,
Jan
Kind regards,
Jan
You're welcome
I agree, unfortunately it requires more than a simple fix (I have some ideas, though).
WroteDocument layout within SMath should be independent from screen size setting, however I'm glad this issue is resolved ;-)
1页(4条)
