Graphs Scaling
Graphs Scaling - 消息
#1 已发布: 2015/3/10 09:45:37
sperez
sperez
0个赞,共1个帖子。
Is it possible to control the scale of the graph axes, using code within the document or an option somewhere.
I'm trying to make the scale conform to a specified domain and range so the graph generated by my functions doesn't have to be manually adjusted every time a variable is changed.
Best Regards,
Santiago
#2 已发布: 2015/3/13 15:34:48
1,443个赞,共2,936个帖子。
Hello Santiago,
For precise scaling/limits you have to use a plugin, such as Maxima plugin (examples) or X-Y Plot Region
A further help is inside the extension mangager (Tools > Plugins...) > Interactive handbooks; here there is the SMath Studio Handbook, that contains a Graphics section. (You have to download it, set it to use as default, then will be available from the Help > Reference book... menu)
