cases and replacement of variable by value
cases and replacement of variable by value - 消息
#21 已发布: 2018/5/2 04:09:38
1,443个赞,共2,936个帖子。
Hello everyone
Shouldn't the variable A be replaced by its value 1 when 'cases' is used instead of 'if/else'?
This is by design and is related to functions and undefined arguments; however if I remember correctly was needed because the old way caes() was coded, I'll check if with current cases() and smath code can be removed. Also, applies ony when cases is on the RHS of functions.
I notice one instance if/otherwise does not work vs if/else.
Reported, not acknowledged ... maybe more than one instance.
No way this can work, because a is defined after the plot; keeping this layout you have to move the vertical position of the plot down or the vertical position of a:0 up
Martin_B 2018/5/2 05:55:00
#22 已发布: 2018/5/2 08:23:22
983个赞,共6,866个帖子。
I really don't want to play silly games with you anymore.
I asked a simple question:
"Why is the value of the canvas variable A not stored in the function, when cases is involved ?"
Your answer has absolutely nothing to do with my question.
Convince yourself, try the right/wrong code in De Boor Colibri.
It may have to do with another next possible not silly visit/question.
Spline De Boor [Colibri].sm (39.34 KiB)已下载 1035 次。
#23 已发布: 2018/5/2 08:49:12
983个赞,共6,866个帖子。
A CAS like Smath and others do not know if
0.123 is exactly = 0.123000000000000
I'm not aware of such an option in Smath
Example from Mathematica 4.0
#24 已发布: 2018/5/2 08:57:09
983个赞,共6,866个帖子。
Explained otherwise in Mathcad/Mathsoft
x^1/2 will output 250 floating point decimals [1/2 is exact]
x^0.5 will output 15 decimals [0.5 is unknown]
#25 已发布: 2018/5/2 09:37:40
983个赞,共6,866个帖子。
... I will leave it from there.
Please, don't hesitate to submit your project.
There was that futile discussion about 32/64/128 floating point
In PC's, 32 bits is enough. Common math functions as delivered
by Microsoft are 21 decimals, uncertain down to 18 decimals
agreed to true 15 decimals taking account of reasonable
numerical errors propagation.
A Mathsoft Collab wanted > 15 decimals. Answer was simple:
Mahcad 11 extended 64 floating point:
Install Chebyshev 25 decimals [Clenshaw, Luke ...]
Accuracy.sm (19.58 KiB)已下载 1258 次。
#26 已发布: 2018/5/2 17:45:55
CBG
CBG
78个赞,共312个帖子。
Originally Posted by: Alyles
引用
The difference comes when the value of A changes after the definition of f(x) and g(x).
For g(x) the original definition of A:=1 remains. However, for f(x) the value of A changes.
I see that the problem is caused by the definition of the variable A, before the functions, changing the definition of this variable after the definitions of the functions, the problem is solved.
This indicates to us that we must be very careful when programming functions when some of the variables that integrate in them have already been defined previously, because we could arrive at erroneous results
cases_ok_cbg.sm (7.02 KiB)已下载 1189 次。
#27 已发布: 2018/5/3 04:54:00
127个赞,共342个帖子。
I think MarB is right. It is advisable to have homogeneous behavior of the functions. In this case, function "cases" is used as an alternative to function "if...else" to avoid using nesting; it is evident that one expects the same behavior.
frapuano 2018/5/3 07:40:00
#28 已发布: 2018/5/3 10:16:30
983个赞,共6,866个帖子。
They do behave the same, except for the rare case that I reported.
In mainy instances < or <= won't matter
In other instance it matters to scrap the project [De Boor re-posted in this thread].
In less visible instance, if the form is not appropriate will freak the project.
Same things with Mathcad ... ad nauseum doctored.
No matter the arguments, Smath is correct, does not forgive user incorrect coding.
#29 已发布: 2018/5/3 11:10:40
Martin_B
Martin_B
22个赞,共84个帖子。
Take a look at post #1 or #3. That's about what we are talking here.
Another example:
The first A is replaced by its value, the second is not.
Not really intuitive or obvious, in my opinion.
sergio 2018/5/3 11:59:00
#30 已发布: 2018/5/3 12:06:00
983个赞,共6,866个帖子。
The best is to apply to a project and make it work.
#31 已发布: 2018/5/3 13:02:11
1,443个赞,共2,936个帖子。
I'm too to not create confusion, however some features are tied to this feature; by removing it:
  • any argument will be preprocessed by smath; this means f.e. that if you place a definition, this will be evaluated despite the condition is met or not (like in if function)
    未找到文件。未找到文件。
  • the protection against assignments won't work anymore
  • won't be possible anymore to use functions like error()
(you will be able do them using line, though)
