Deleting Rows an Columns
Deleting Rows an Columns - Matrice Handling - 消息
#1 已发布: 2021/5/30 22:31:23
600个赞,共1,381个帖子。
Some functions for row and column deletion.
For row and column functions accepts horizontal and vertical vectors, range(2) and range(3), numbers.
No need to convert anything during input, and exceeding and subceeding values not be removed.
delete_rowcol.sm (21.39 KiB)已下载 1458 次。 (old method)
delete_rowcol.sm (15.58 KiB)已下载 1446 次。 (new and faster method)
sergio 2021/5/31 05:16:00
#2 已发布: 2021/5/31 08:01:39
983个赞,共6,866个帖子。
Otherwise useful ... you delete what you don't select.
sergio 2021/5/31 08:16:00
#3 已发布: 2021/6/1 00:23:20
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Alternate program. Very fast on large matrix.
Jean's program very helpful. Thank you Jean
New_Matrix_Delete [col_row].sm (24.06 KiB)已下载 1327 次。
2位用户喜欢此帖子
overlord 2021/6/3 21:45:00, sergio 2021/6/1 04:28:00
#4 已发布: 2021/6/1 11:30:22
600个赞,共1,381个帖子。
I tried your solution and found out it is faster with single row or single column removal. Good job.
And also found out transpose method is way much slower if I use ranges or matrices for input.
That method is not fast enough and not a good method when you use vectors of columns or rows for removal.
So I have combined your solution with mine, a fast and feature-full method is born.
New file is added in first post.
NDTM Amarasekera 2021/6/1 13:29:00
#5 已发布: 2021/6/1 12:52:21
983个赞,共6,866个帖子。
From square/rectangular matrix algo style do all at will.
1. delete cols & rows in any shuffled ways.
2. conserve selected rows deleted of 'j'.
3. conserve selected cols deleted of 'j'.
Hopefully, no red in your SS version !
Thanks, be good ... Jean.
Utilities Matrix Minor [col_row] ADVANCED OTHERWISE Copy.sm (21.58 KiB)已下载 1346 次。
#6 已发布: 2021/6/1 13:28:36
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Yes it works fast. It is a smart code with added features.
Thank you.
#7 已发布: 2021/6/2 15:34:35
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
A revised version, to delete multiple non-adjacent columns.
Faster on large matrix than my last example in post #3.
New_Matrix_Delete [col_row]_R2.sm (41.9 KiB)已下载 1313 次。
2位用户喜欢此帖子
overlord 2021/6/3 21:45:00, Alvaro 2021/6/2 17:53:00
#8 已发布: 2021/6/2 18:12:03
1,139个赞,共1,805个帖子。
Hi Amarasekera. Please try this other version, which works for single column values or column ranges.
New_Matrix_Delete [col_row]_R2.sm (38.79 KiB)已下载 1286 次。
2位用户喜欢此帖子
overlord 2021/6/3 21:45:00, NDTM Amarasekera 2021/6/2 23:47:00
#9 已发布: 2021/6/2 18:35:44
983个赞,共6,866个帖子。
NDTM Amarasekera 2021/6/2 23:48:00
