Infinite loop problem?
Infinite loop problem? - 消息
#1 已发布: 2010/8/6 17:05:07
325个赞和1个踩,共2,052个帖子。
Hello Andrey,
I think this should be a bug.
[MATH]f(x)←5+f(x)[/MATH]
[MATH]f(1)=#[/MATH]
This will not stop executing until it is interrupted. I think this is an infinite loop problem.
#2 已发布: 2010/8/6 20:18:55
2,344个赞,共4,057个帖子。
组: Super Administrator
Hello.
Thank you. Will check this later.
Regards.
#3 已发布: 2010/8/18 06:55:06
Greg Locock
Greg Locock
0个赞,共53个帖子。
what behaviour would you expect?
you are asking for 5+5+5....
#4 已发布: 2010/8/18 07:27:35
Yes, Greg, that is the problem. We can have something like this:
[MATH lang=eng]f(x)←x[/MATH]
[MATH lang=eng]f(x)←f(x)/2[/MATH]
[MATH lang=eng]f(5)=2.5[/MATH]
But with this, we get in trouble.
[MATH lang=eng]f(5)=#@#[/MATH]
The question is - Does it to be the user's problem to interrupt such a calculation or to suppress it by an error message? I was not sure about it, and that was my doubt about "endless loop".
#5 已发布: 2010/9/29 18:11:03
2,344个赞,共4,057个帖子。
Fixed.
#6 已发布: 2010/9/30 03:10:33
Hello Andrey,
Sorry for being persistent, but I think I was not precise enough. The previous calculation will work in SMath - there was not a problem.
But, try this:
The problem is that this will never stop, until we "Interrupt processing". My question was - Should it be left this way or should it be stopped by SMath.
#7 已发布: 2010/9/30 08:52:55
2,344个赞,共4,057个帖子。
This is also fixed. Now SMath Studio understands that it is not good practice to repeat substitution of the already substituted functions with the same names So one will not see infinite loops in such cases anymore.
Regards.
Radovan Omorjan 2010/9/30 09:05:00
