Saving Error
Saving Error - File saved but changes made disappeared - Messages
#1 Posted: 2020/6/24 22:38:42
gharrington
gharrington
0 likes in 2 posts.
Dear All,
I recently saved an sm file overnight and when I opened this morning the changes I made were gone! The time stamp on the file is correct (~1 AM) but none of the changes I made between 5 PM and 1 AM are shown. I finished with over 30 pages but now the file is down to 18.
I used SMath File Recovery Development Tool and the "XML structure is not corrupted"
I am new to this program and using the most recent version. I've attached the file (last saved at 12:58 AM 06/24/2020). Can someone please help me restore?
Drilled Shaft Axial Capacity - Makai & Mauka Abutment Analysis (2020-06-16 GH).sm (4.24 MiB) downloaded 1249 time(s).
Thank you
#2 Posted: 2020/6/25 06:56:08
1,441 likes in 2,932 posts.
Very strange... It is possible that you had the same file opened twice in the same instance?
2020-06-25 11_56_34-SMath Studio - [Drilled Shaft Axial Capacity - Makai & Mauka Abutment Analysis (.png
#3 Posted: 2020/6/25 07:02:01
Unlikely it has to do with the SS version. Rather the Win.
"Save" may save anywhere for several times... then where ?
"Save as" saves where you address, as you have it on screen.
Your document did not evaporate by itself.
#4 Posted: 2020/6/25 13:40:53
That is the right answer, common mishandling.
#5 Posted: 2020/7/3 16:10:28
gharrington
gharrington
0 likes in 2 posts.
Thank you both for your help! I will not make this mistake again
