numeric display
numeric display - numeric display - 消息
#1 已发布: 2024/3/26 22:36:24
TopUser2000
TopUser2000
0个赞,共28个帖子。
Hello. Tell me, please, is it possible to see the set numerical values when calculating formulas in the program? I mean, instead
of
a = 5, b = 6,
a + b = 11
see a = 5, b = 6,
a + b = 5 + 6 = 11
#2 已发布: 2024/3/27 09:21:28
churichuro
churichuro
29个赞,共79个帖子。
test1.sm (5.06 KiB)已下载 1551 次。
#3 已发布: 2024/3/27 16:56:37
TopUser2000
TopUser2000
0个赞,共28个帖子。
In the simplest case, this option would be suitable, but if the formula is a little more complicated, then we get a pile of fractions and numbers
#4 已发布: 2024/3/28 19:54:32
Arie
Arie
94个赞,共285个帖子。
FYI there has been some discussion about this feature in the past.
https://en.smath.com/forum/yaf_postst23575_Substitution-Optimization.aspx
Also a function proposed here: https://en.smath.com/forum/yaf_postsm78024_substitute-variables.aspx#post78024
#5 已发布: 2024/3/28 23:26:08
TopUser2000
TopUser2000
0个赞,共28个帖子。
FYI there has been some discussion about this featurein the past.
https://en.smath.com/for...tution-Optimization.aspx
Also a function proposed here: https://en.smath.com/for...variables.aspx#post78024
But there is no solution for this request there...
#6 已发布: 2024/3/29 02:29:38
600个赞,共1,381个帖子。
There is also this topic.
https://en.smath.com/forum/yaf_postst21565_Show-values.aspx
What you seek is won't be simple, as you requested and applicable however.
This situation is explained in detail by mkraska at the link above.
#7 已发布: 2024/3/29 11:58:56
⚜ Kenny Lemens, P.E. ᵂᴵ
85个赞,共181个帖子。
Greetings,
Alvaro has built a function to address this feature request:
Note: it has a little bit of a learning curve, but is worth considering never-the-less.
May this be of Good Help;
#8 已发布: 2024/3/30 01:40:58
TopUser2000
TopUser2000
0个赞,共28个帖子。
I don't see the result in the attached screenshots of how it works. A jumble of formulas where there is no clear answer.
