unit for torque moment ? - 消息
Regard
Konrad
And "J" is not the correct Unit (in SI-System)
http://en.wikipedia.org/wiki/International_System_of_Units
http://en.wikipedia.org/wiki/Torque
From WIKI for Torque:
引用
Units
Torque has dimensions of force times distance. Official SI literature suggests using the unit newton metre (N·m) or the unit joule per radian.[7] The unit newton metre is properly denoted N·m or N m.[8] This avoids ambiguity with mN, millinewtons.
The joule, which is the SI unit for energy or work, is dimensionally equivalent to a newton metre, but it is not used for torque. Energy and torque are entirely different concepts, so the practice of using different unit names for them helps avoid mistakes and misunderstandings.[7] The dimensional equivalence of these units, of course, is not simply a coincidence: A torque of 1 N·m applied through a full revolution will require an energy of exactly 2π joules. Mathematically,
E= \tau \theta\
where E is the energy, τ is magnitude of the torque, and θ is the angle moved (in radians). This equation motivates the alternate unit name joules per radian.[7]
Other non-SI units of torque include "pound-force-feet", "foot-pounds-force", "inch-pounds-force", "ounce-force-inches", and "metre-kilograms-force". For all these units, the word "force" is often left out,[9] for example abbreviating "pound-force-foot" to simply "pound-foot". (In this case, it would be implicit that the "pound" is pound-force and not pound-mass.)
Regard
Sorry but I think you did it wrong.
It is not 'Nm but 'N*'m. See the example please:
[LIVE width=322 height=219]http://smath.info/live/?file=1938[/LIVE]
noxx, I only wanted to explain to you why SMath (or Mathcad) gives you Joules when you multiply Newtons by meters. It doesn't suprise me at all, in fact it is the correct behaviour.
Mit freundlichen Grüssen
Konrad
Konrad
WroteHello,
Is there any way that I can set N.mm as default unit instead of J ? I am a structural engineer, working pretty much with Nmm, and I need N.mm everywhere in the calculation smath studio sheet, it is odd to see "J" unit in structural engineering calculation, and I just don't want to change J to N.mm here and there all the times. Thank you very much in advance. (PS:// Smath Studio is the best free tool I have ever had )
WroteHello.
i'm not able to have NM like you. Why?
- units are case sensitive. Capital M is no unit.
- press N then tab, then *, then m then tab
Image:
http://snag.gy/n4ZRf.jpg
Can anyone walk me through the steps for achieving the results in N*m? Isn't a major issue, but it would be nice to know how to do this.
WroteI typed it in the way kadpeter's example shows, but I'm still getting Joules as the resulting unit of measure...
The portable distribution with Maxima has an integrated interactive handbook, accessible via the blue question mark button in the toolbar. There is a chapter on units and a page on units in results display. Let me know if that does not help, may be the description requires improvement.
Because you didn't enter the apostroph. In Kadpeter's example you have to type 'Nm:=N*m The apostroph will disappear and Nm become blue
@brotjob: That solved my problem, and my custom units are working more-or-less as I would like them.
Edit: the "Thank" button returns an error. "An error occured."....
